Bigger Radiator Question???????????????????
Old Sep 29, 2005 | 05:21 AM
DeDonDeRosa's Avatar
Default Bigger Radiator Question???????????????????
ok heres the question
someone told me that when u install a bigger rad into like a gsr depending on the cap you use or whatnot that the computer thinks all the time that the car is still warming up and the car will not engage into vtec.
so will vtec not work because the ecu thinks the car is still warming up or what ?
would it affect it at all because the cooling temp is lower than stock now and the ecu is looking for that certain temp ????
Old Sep 29, 2005 | 08:35 AM
Default Re: Bigger Radiator Question??????????????????? (DeDonDeRosa)
ANYONE?
Old Sep 29, 2005 | 09:15 AM
JimBlake's Avatar
The cap controls pressure; or more accurately LIMITS pressure. That only indirectly controls temperature.
The thermostat controls temperature directly. If you have the right thermostat, your engine will warm up correctly. If your ECT sensor is working correctly, then your ECU will know when it's warmed up.
Old Sep 29, 2005 | 09:23 AM
Default Re: Bigger Radiator Question??????????????????? (JimBlake)
WELL STOCK THERMOSTAT AND SWTICH SO.....
JUST A NEW KOYO RAD
THAT WOULDNT EFFECT VTEC WOULD IT ?
Old Sep 29, 2005 | 09:54 AM
JimBlake's Avatar
That radiator by itself shouldn't screw up VTEC.
Old Sep 29, 2005 | 10:06 AM
domino's Avatar
A larger radiator with a stock thermostat will not lower the water temp.
PreludeRacer023
Dec 11, 2014 06:46 AM
cjwarren4dacord
Nov 27, 2010 04:13 AM
soon2bdropped
Jan 15, 2007 03:41 AM
stealth civic
Jan 21, 2005 05:23 PM
DeDonDeRosa
May 1, 2003 02:13 PM
