vtec solenoid leaking
Old Sep 29, 2005 | 05:18 AM
awps's Avatar
Default vtec solenoid leaking
i have been losing oil and have come to the conclusion that my vtec solenoid is leaking, where it connects to the head. there is oil on the side of the head right underneath the solenoid and i clean it off all the time, and whenever i open the hood i can see a burned stream of oil going down. is there some kind of seal from acura that i can get and replace to stop this? also, has anyone ever had this happen to them?
Old Sep 29, 2005 | 05:41 AM
iakona's Avatar
there is a replacement gasket you can get from acura. shouldn't set you back more than $20.
Old Sep 29, 2005 | 05:55 AM
awps's Avatar
Default Re: (iakona)
i was looking at the diagram. i think it's #8 on here... if not, does anyone know what part it is.
Old Sep 29, 2005 | 06:00 AM
Ekay Jay's Avatar
Default Re: vtec solenoid leaking (awps)
#8 looks like the cam seal.
Old Sep 29, 2005 | 06:02 AM
iakona's Avatar
yep. #12 is the VTEC solenoid gasket and filter.
Old Sep 29, 2005 | 06:05 AM
awps's Avatar
alright, that still doesn't look like that circle rubber piece on the outside of the head. it's like circle, that gasket doesn't look like whats on the outside of the car, but i guess i could go get one and see if it helps.
Old Sep 29, 2005 | 08:13 AM
Dee's Avatar
Dee
Default Re: (awps)
Do yourself a favor!! Change both #8 AND #12. It doesn't cost that much and the install will take you 30~45 minutes while chugging on refreshments and dreaming about upgrades for your sweetheart!
Old Sep 29, 2005 | 09:10 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Yep, and be sure to get the redesigned version of the #8 cam seal. The old style was a rubber plug. The newer style is plastic w/ 2 o-rings. I replaced mine with the new style plug, and nearly 100K miles later still no leaks.
Old Sep 29, 2005 | 09:25 AM
awps's Avatar
Default Re: (PatrickGSR94)
how can i be sure i am getting the new one?
Old Sep 29, 2005 | 09:26 AM
awps's Avatar
Default Re: (awps)
oh yea, and what about #10. it has the same description in the listing, and costs the same amount of $.
Old Sep 29, 2005 | 09:27 AM
CNSK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">Yep, and be sure to get the redesigned version of the #8 cam seal. The old style was a rubber plug. The newer style is plastic w/ 2 o-rings. I replaced mine with the new style plug, and nearly 100K miles later still no leaks. </TD></TR></TABLE>
I think im leaking on my str cam seal, .......has nearly 80k miles on it......I was wondering if I can just replace the o-rings on it...but i may just end up buying just to save headache...not much anyways...
Old Sep 29, 2005 | 09:31 AM
Community Builder
Default Re: (awps)
#10 is just the screen. #12 is the screen and gasket together.
When I ordered my cam plug, I told them I wanted to the newer version. They probably don't even have the older one anymore, but better check to make sure when you order it.
Old Sep 29, 2005 | 09:33 AM
awps's Avatar
well i'm just getting the part number off acuraparts247.com, then going to a honda dealer on the way home. i still have to call them and see if they have it first. i guess i will find out when i get there if it's the new one or not.
Old Sep 29, 2005 | 09:40 AM
awps's Avatar
Default Re: (awps)
damn, i just called them and they don't even stock #12. they only have #8. boo.
Old Sep 29, 2005 | 11:08 AM
awps's Avatar
Default Re: (awps)
Ok, i just found a dealer with it. i was thinking though. do i have to take the valve cover off in order to install the cam seal? or can i do it from the outside when i take the solenoid off to replace the #12 part? anyone know?
Old Sep 29, 2005 | 11:44 AM
Community Builder
Default Re: (awps)
valve cover must come off, c-speedracing.com has a how-to.
Why don't you just order everything you need online? It's not like you absolutely must get this done today, is it?
Old Sep 29, 2005 | 11:48 AM
awps's Avatar
no, but why pay like $10 in shipping and handling when i can just get it from the dealer. the price is only a few $ off from the dealer and online. most places have 4.95 handling and 4.95 shipping so it isn't worth it. i only order online if it's an expensive part.
Old Sep 29, 2005 | 01:24 PM
awps's Avatar
Default Re: (awps)
alright, so i went there, and part #8 isn't a cam seal, it's like the plug that would go on the head if the solenoid wasn't there. and they said they had part #12 but they couldn't find it. so i guess i have to go to a different dealer.
Old Sep 29, 2005 | 06:51 PM
Dee's Avatar
Dee
Default Re: (awps)
When I bought my VTEC solenoid gasket (#12) it came with the screen (#10). Get the screen too!
If you notice, #12 points to both the screen and gasket. #10 is the screen only.
Old Sep 29, 2005 | 08:09 PM
Jdm94gsr's Avatar
Default Re: (Dee)
My solenoid seal was leaking before, so was my cam seal but i only replaced the soleniod seal an screen cause i didnt know they were both leaking. But Heres Some good info on replacing the cam seal.
http://www.team-integra.net/se...e.asp?
Old Sep 29, 2005 | 08:19 PM
Community Builder
Default Re: (awps)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by awps &raquo;</TD></TR><TR><TD CLASS="quote">alright, so i went there, and part #8 isn't a cam seal, it's like the plug that would go on the head if the solenoid wasn't there. and they said they had part #12 but they couldn't find it. so i guess i have to go to a different dealer.</TD></TR></TABLE>
All B-series engines have a cam end seal at the end of the exhaust camshaft, both VTEC and non-VTEC engines.
You can see mine here, the black circle right behind the gold-colored bolt near the bottom middle of the pic (and yes that is a VTEC solenoid in front of it ):
98_ssbp
Oct 11, 2012 10:45 AM
yoffer
Aug 21, 2012 03:23 PM
egtony
Jul 2, 2009 11:59 PM
miro_gt
Jan 26, 2009 10:55 AM
kin_8
Jul 9, 2004 05:41 PM
