B18b sensors
Hi all, just bought a 95 B18b w/11k miles to swap into my rex. I'm trying to sort out the sensors. The one on the back of the throttlebody is obviously the throttle angle sensor, but there is one on top of the throttlebody, is this the map sensor? There is also one on #4 intake runner, what is it? My little hf motor don't have them in the same place.
TIA
chris
TIA
chris
the sensor on the top of the T/B is a MAP sensor.
the sensor you see on the IM runner would me the air intake temprature sensor. most newer OBD2 civics have that sensor usually before the T/B on the intake pipe.
if your gonna swap the B18B into your civic you might want to get a Integra LS engine wiring harness. it will make it much easier.
