GSR RRRRRRRR
Old Sep 28, 2005 | 10:08 PM
EJ1SPEC95's Avatar
Default GSR RRRRRRRR
Yo what up H-T I got a problem every time shift I get wierd sound like old truck(hard to explain the sound) please help
Old Sep 28, 2005 | 10:10 PM
WongFeihung's Avatar
Default Re: GSR RRRRRRRR (EJ1SPEC95)
replace clutch.
Old Sep 28, 2005 | 10:12 PM
Luserkid's Avatar
Is it grinding? replace the transmission.
Old Sep 28, 2005 | 10:13 PM
FalkenSiR's Avatar
Default Re: GSR RRRRRRRR (Luserkid)
Replace car.
Old Sep 29, 2005 | 02:18 AM
JDM_sedan's Avatar
you..... are............ STUPID
Old Sep 29, 2005 | 05:47 AM
IHateJDM's Avatar
Default Re: GSR RRRRRRRR (JDM_sedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_sedan &raquo;</TD></TR><TR><TD CLASS="quote">you..... are............ STUPID</TD></TR></TABLE>
and you have nothing better to do than post a retarded comment in every single thread in this forum. You need to get a life.
Old Sep 29, 2005 | 05:59 AM
Ricey McRicerton's Avatar
This is your warning. If you don't have anything to add, don't post.
Old Sep 29, 2005 | 07:58 AM
EJ1SPEC95's Avatar
Default Re: GSR RRRRRRRR (IHateJDM)
speed BUMP Im stupid thanks for the positive feed back JDM FAMILY WAGON
Old Sep 29, 2005 | 08:01 AM
kleanlscivic's Avatar
does it like badfire or just a grinding noise?
Old Sep 29, 2005 | 08:12 AM
EJ1SPEC95's Avatar
Default Re: GSR RRRRRRRR (kleanlscivic)
It does not back fire or grind
Old Sep 29, 2005 | 08:14 AM
IHateJDM's Avatar
is the motor hesitating, or is it not engaging the gears smoothly?
Old Sep 29, 2005 | 08:16 AM
EJ1SPEC95's Avatar
Ok when shift and release the clutch and pressing on the gas get this wierd noise
Old Sep 29, 2005 | 08:18 AM
JDM-97CX's Avatar
Not a single person here can help you if all you say is you get a weird noise like an old truck.
And just because you get a grind doesn't mean you need a new trans.
Old Sep 29, 2005 | 08:22 AM
VWVORTEX's Avatar
Default Re: GSR RRRRRRRR (JDM-97CX)
it's 2005 dood, if you can't afford a camera to take a video, then find a hobby you can afford while your at it..
GO TAKE A VIDEO OF THE WERID NOISE.... or try to describe it using english words like grind, high pitch, stutter, rattle, clunking, etc
Old Sep 29, 2005 | 08:26 AM
JDM-97CX's Avatar
Default Re: GSR RRRRRRRR (GripStar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GripStar &raquo;</TD></TR><TR><TD CLASS="quote">it's 2005 dood, if you can't afford a camera to take a video, then find a hobby you can afford while your at it.. </TD></TR></TABLE>
I can't afford a video camera. Are you saying I should sell my car right now and change careers while I'm at it as well? GTFO.
Old Sep 29, 2005 | 08:30 AM
mattssi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1SPEC95 &raquo;</TD></TR><TR><TD CLASS="quote">Yo what up H-T I got a problem every time shift I get wierd sound like old truck(hard to explain the sound) please help </TD></TR></TABLE>.
you need to be more specific. And type clearly so that the general audience can understand you
Old Sep 29, 2005 | 08:35 AM
VWVORTEX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-97CX &raquo;</TD></TR><TR><TD CLASS="quote">I can't afford a video camera. Are you saying I should sell my car right now and change careers while I'm at it as well? GTFO.</TD></TR></TABLE>
you can't afford a camera, yet you have 4000 posts, and spend all day on honda-tech.. maybe you should get a job
EJ1SPEC95's Avatar
GO TAKE A VIDEO OF THE WERID NOISE.... or try to describe it using english words like grind, high pitch, stutter, rattle, clunking, etc</TD></TR></TABLE>
DOOD Your so freaking right, are like DR. Phil or Oprah?
heat BUMP to my financial adviser (GripStar)
Old Sep 29, 2005 | 08:37 AM
VWVORTEX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1SPEC95 &raquo;</TD></TR><TR><TD CLASS="quote">DOOD Your so freaking right, are like DR. Phil or Oprah?
heat BUMP to my financial adviser (GripStar) </TD></TR></TABLE>
lol.. i hope your drunk
Old Sep 29, 2005 | 08:39 AM
EJ1SPEC95's Avatar
lol i dont drink
Old Sep 29, 2005 | 08:42 AM
VWVORTEX's Avatar
dood.. WHAT DOES IT SOUND LIKE... DERKA DERR JERB ?
Old Sep 29, 2005 | 08:50 AM
EJ1SPEC95's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GripStar &raquo;</TD></TR><TR><TD CLASS="quote">dood.. WHAT DOES IT SOUND LIKE... DERKA DERR JERB ?</TD></TR></TABLE>
sounds just like that serious
Old Sep 29, 2005 | 08:54 AM
VWVORTEX's Avatar
Old Sep 29, 2005 | 09:06 AM
viskii420's Avatar
check the transmission mounts if it grinds and its a new trenny.. if u rev high rpm and the car is goin slow then is the clutch.. when u say it sounds like a truck then check the axels..
Old Sep 29, 2005 | 09:07 AM
EJ1SPEC95's Avatar
what does that mean
