speedometer doesnt work help!!!!!!!!!!
or maybe you ruined it or broke it when you took it out. happened to mine and have been without it for 2 months now
kinda used to it now though
like are they easy to brek or something when u take them off cause everything is plugged up and i just need to get this speedo workin today
Speedo cable is the culprit 99% of the times. As stated above, make sure that the speedo cable is properly secured with by the slip-clip. If not, then you will definately have to replace.
USDM 4G VTEC
Jan 31, 2003 10:19 PM
