gsr manifold question
just out of curiousity, if i put a dual stage gsr manifold on other b series like the LS , and if it fits, will u b able to hear the 2nd tone kick in at 5700
First off, the GSR manifold only fits GSR heads, and to operate the secondaries you need to have either a GSR or H22 ECU. You could wire it up with an RPM activated switch if you wanted to.
But this still doesn't explain why you would want to. Odds are this would offer little or no performance benefit on a motor like an LS motor. There's a reason why people swap to manifolds like the Skunk2 and Blox.
yeah kinda what kendall said...the b18c1 IM will only work on that head. the 92 GSR IM will work on the b16/b17/b18c5 heads.
later
casey
92 gs-r #1367
later
casey
92 gs-r #1367
