gsr with different head
Old Sep 28, 2005 | 04:45 PM
94gsrvtek19
Guest
Posts: n/a
Default gsr with different head
i have a 94 gsr with a different 94 gsr head from an ls-vtec. i took this head becuase my head is blown.do u think itll run the same as b4??
Old Sep 28, 2005 | 04:48 PM
Chewie's Avatar
Default Re: gsr with different head (94gsrvtek19)
did you do any damage to the bottom when the head blew? if the condition of the heads are similar, should be about the same.
Old Sep 28, 2005 | 04:50 PM
94gsrvtek19
Guest
Posts: n/a
Default Re: gsr with different head (Chewie)
no damage was done to the block. just a blown head, so i replaced the head. and also slapped on a sk2 manifold. im dissapointed, can it be because of the sk2 manifold? or should i put back my stock manifold?
Old Sep 28, 2005 | 04:52 PM
numotive's Avatar
from what i gather, if you are running stock gsr cams, you should stick with the stock dual stage intake manifold or you will loose low end power. only upgrade to a type-r or skunk2 intake manifold if you are going to upgrade the cams as well.
Old Sep 28, 2005 | 04:56 PM
94gsrvtek19
Guest
Posts: n/a
Default Re: gsr with different head (numotive)
if i upgrade my cams, can i still use stock p72?? i ran a chipped p28 by phearable and it feels almsot the same, just different vtec point. and also, will new cams make my vtec hit harder
Old Sep 28, 2005 | 05:50 PM
kchungb17a's Avatar
You will need to adjust the VTEC engagement to 5500 - 5800, depending on cams. A dyno tune will tell you exactly where to set it. The stock P72 VTEC point is too low for a large single stage manifold like the Junk2. While you're at it, get some better valve springs so you can get a couple extra hundred rpms in.
carbonn
May 31, 2009 06:54 AM
2ndchirp
Feb 17, 2009 06:00 AM
frostyrb
Mid-Atlantic (Sales)
Oct 23, 2008 05:02 PM
ninety1_octane
Mar 24, 2006 12:39 PM
ThatRicerDaniel
Jul 2, 2003 09:59 AM
