skunk2 manifold or stock on gsr
Old Sep 28, 2005 | 04:39 PM
94gsrvtek19
Guest
Posts: n/a
Default skunk2 manifold or stock on gsr
i have a gsr and recently installed a sk2 manifold. i lost alot of torch and i also ran a chipped p28 by phearable and it kinda feelz stock. should i put back in my stock gsr manifold for torch and daily driving?? or stick with sk2 manifold??
Old Sep 28, 2005 | 04:42 PM
aZnjCC's Avatar
are you plannin on running some bigger cams than stock? if you are than definately stick with the sk2 manifold.
but if that's all you're gonna do, honestly go back to ur stock manifold for more "torch"
Old Sep 28, 2005 | 04:45 PM
Chewie's Avatar
Default Re: (aZnjCC)
Unless you put some cams in, you wont see much gain with the im.
p.s. torque. honda doesnt have torque anyway.
Old Sep 28, 2005 | 04:47 PM
94gsrvtek19
Guest
Posts: n/a
Default Re: (Chewie)
can i just throw in some cams and expect sum gains? or do i also need to upgrade on othe things
Old Sep 28, 2005 | 04:53 PM
aZnjCC's Avatar
think of it this way...everything u put on adds a little power. when you have all the little things together as a package, you benefit even more.
Old Sep 28, 2005 | 05:36 PM
numotive's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aZnjCC &raquo;</TD></TR><TR><TD CLASS="quote">think of it this way...everything u put on adds a little power. when you have all the little things together as a package, you benefit even more.</TD></TR></TABLE>
not really... if he just puts on the skunk2 IM then hes gonna loose power. u need the IM and the cams together to see any increase in performance
Old Sep 28, 2005 | 05:45 PM
kchungb17a's Avatar
Default Re: (numotive)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by numotive &raquo;</TD></TR><TR><TD CLASS="quote">
not really... if he just puts on the skunk2 IM then hes gonna loose power. u need the IM and the cams together to see any increase in performance</TD></TR></TABLE>
Well, I'd argue that he just lost a bunch of lower end power. Up at the top he might have gained a couple points. BTW with that manifold, f your VTEC engagement is anywhere below 5500-ish, it's too low.
advaneh3
22
Nov 4, 2008 03:53 PM
dc2_4life
Jun 11, 2007 10:00 PM
GSRVTEC1
Feb 15, 2006 11:46 AM
gsrvtec2
Oct 5, 2005 05:07 PM
envious1320
Jul 12, 2003 02:48 PM
