intake namebrand or generic
Old Sep 28, 2005 | 02:47 PM
tegra96's Avatar
Default intake namebrand or generic
i am in the market for a new intake for my 96 teg. does it make a big difference if i get a cheap intake as oppose to a name brand like injen or aem. am i gonna gain the same hp.
Old Sep 28, 2005 | 02:59 PM
h4x's Avatar
h4x
No difference whatsoever. Get a 10 dollar ebay one.
ERIC!'s Avatar
Default Re: intake namebrand or generic (tegra96)
its in the filter not the piping as much. get an ebay generic intake, short ram or cold air, then upgrade the filter with a k&n or something of high quality.
Old Sep 28, 2005 | 04:47 PM
projectTeG's Avatar
Default Re: intake namebrand or generic (elephantegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elephantegra &raquo;</TD></TR><TR><TD CLASS="quote">its in the filter not the piping as much. get an ebay generic intake, short ram or cold air, then upgrade the filter with a k&n or something of high quality.</TD></TR></TABLE>
also id say alluminum piping is better, ive seen some genic ones with steel piping which adsorbs more heat.....heat soaks bad./
Old Sep 28, 2005 | 06:02 PM
Horseman's Avatar
Are you kidding me?? Get a known brand, a chrome metal one will NOT give you power (maybe 1hp) metal intakes soak heat, thats why i will be changing mine soon, cause i have a metal one, the bigger the piping the better! but prolly not bigger than 4"
Old Sep 28, 2005 | 06:19 PM
projectTeG's Avatar
Default Re: (Horseman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Horseman &raquo;</TD></TR><TR><TD CLASS="quote">Are you kidding me?? Get a known brand, a chrome metal one will NOT give you power (maybe 1hp) metal intakes soak heat, thats why i will be changing mine soon, cause i have a metal one, the bigger the piping the better! but prolly not bigger than 4"</TD></TR></TABLE>
hey, learn something....aluminum is metal which most are aluminum, i just stated make sure that your dont get a steel one, also the bigger is not better,,,,its the same cocepts as exhausts you need to remove restrictions, but keep the air velocity. 4" is way to big the largest id say go would be 3" and the smallest maybe 2.25". put its mostly all in the filter if the pipe is good.
mwaedow
Feb 15, 2010 12:57 PM
gemz00Lude
Feb 19, 2007 04:52 PM
periwinkle
Oct 10, 2005 06:22 PM
hometheaterman
Apr 18, 2005 07:58 AM
gogokid
Sep 30, 2004 09:10 PM
