need serious guidance for a race this weekend....
i got a couple races set up for this weekend and a buddy of mine is coming down from orlando and wants to put a nitrious kit on my car w/ a 50 shot.... im a lil nervous bout the idea... is that a smart idea on a soh nonvtech 1.6 ltr si? dont wanna do anything to damage my motor... i have a few mods but nothing special... intake exhaust and shortshifter( not that shortshifter helps any)... i need as much advice as possible before friday plz cause im totally lost on this one...
the 50 shot should be good as long as you have extra fuel to accomodate it... is it a wet kit? if it is then youre fine... a dry kit would require some other means of getting more fuel into the motor
-Josh
-Josh
what type of racing will you be doing?
u will be fine with a 50 shot on ur stock motor...just dont spray out of the hole if u are drag racing...dont miss shifts...dont over rev ur motor....dont hit ur rev limiter and u should be fine
ok i found out that for a dry kit to be safe id have to retard my timing, cooler spark plugs, premium or better gas, and increase my fuel, so all this= not worth it for one weekend from what i understand.... does anyone here think im right lol
From: behind the dumpster, w./your bitch, w./your bitch
the key to nos longevity is a good fuel system and tuning, setting the timing back and colder plugs can be good ideas if necessary. i would recommend if going with a dry setup on a sohc 1.6 starting w./a small jet (nos tech line can recommend, and they are cool there) and woking up to the prospective jet they recommend. on my '86 civic w./b16 i used a .036 jet -2 deg timing a 1 step colder plugs, bcpre7's i think. that equated to @ 125 shot i believe, tons of fun in that little car 13.6 @105
Hmm colder spark plugs and retarded timing. Any engine can hold a 50 shot of nos if prepared right and used CORRECTLY.
-Jon
-Jon
nitrous is all good , just be conservative.
Be careful of your friend installing it , if he is like me he will try to sneek in a bigger jet for more power
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88 Crx Si »</TD></TR><TR><TD CLASS="quote">Read Sig
its soo funny because its true
</TD></TR></TABLE>its soo funny because its true
