help code 10 asap
i just finnished my zc swap went to fire it and got a code 10 intake air temperature sensor ! i checked it with a meter and read 2.45 oms. so it checks out ok. would it be the ecu or in my wiring i used my dx harnes and never changed the IATS i need some help here asap i want to here this thing run help help help
what the hellll...i can`t get this thing fuurk`n thing running. it`s giving me a code 10.. man this is pissing me off this is what i`ve done i`ve tryed a si ecu still code 10 and i changed the intake air temp sensor still a f`n code 10. should it run with a code 10 or not .... what the hell is wrong anyone PLEASE I NEED SOME HELP
i`m thinking it`s in my wiring. but i checked it and rechecked and maybe it`s a timing thing why it won`t start it`s got spark and i can smell gas. anyone know if the itc go to the b plug on the ecu.. i had to cu8t the plug off and put a new one on for the b15/b16 wires and i think i may have screwed it up
One thing that really had me goin bout my ZC swap wuz figuring out the wiring. In the end the cause of the confusion was the way Honda numbers the wires in their connectors. Molded on the black ECU wire connectors are small #'s that go like this (if your holding the connector so your looking into the holes)...
12345...
6789... this is just an example
but Honda numbers the wires like this...
1357...
2468...
Didn't find that one on any of the ZC swap sites. Just glad I didn't start cutting and splicing till I figured it out. Not saying this is what you did, but just thought I'd mention it just in case.
Good Luck!
12345...
1357...
2468...
Good Luck!
