Help with a B16A setup. Getting some cams.
Old Sep 28, 2005 | 09:59 AM
ziich2's Avatar
Default Help with a B16A setup. Getting some cams.
JDM B16A block
skunk2 valvetrain
mugen 2 layer headgasket
CTR pistons
VAFC
Next week I'll have Blox Tuner B cams and Spoon cam gears. Probably getting a new OEM timing belt also.
What else do I need to get this setup to run correctly? Are these cams big enough that I'll need bigger injectors?
Old Sep 28, 2005 | 02:04 PM
Rocket's Avatar
Default Re: Help with a B16A setup. Getting some cams. (ziich2)
Are the CTR pistons already installed B16 rods?
Old Sep 28, 2005 | 02:22 PM
Suck my DX's Avatar
Default Re: Help with a B16A setup. Getting some cams. (Rocket)
u would need to upgrade ur LMA to accomodate those high lift cams...
the nipples on the 1g b16 were not made large enough with a high lift cam...there is a chance that they may slip at full vtec lift causing ur rocker to bind potentially destroying ur head..u would need to go with itr/gsr/prelude with a shim ones to make it work...i would go with the prelude ones...they are way cheaper than the rest and they work just as good if not better...dr disco was telling me that the prelude ones have a slightly larger diameter than the gsr/its ones...i believe rlz will modify ur stock ones for like 50 bucks
Old Sep 28, 2005 | 05:57 PM
ziich2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket &raquo;</TD></TR><TR><TD CLASS="quote">Are the CTR pistons already installed B16 rods?</TD></TR></TABLE>
Yes
Old Sep 28, 2005 | 05:58 PM
ziich2's Avatar
Default Re: Help with a B16A setup. Getting some cams. (Suck my DX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX &raquo;</TD></TR><TR><TD CLASS="quote">u would need to upgrade ur LMA to accomodate those high lift cams...
the nipples on the 1g b16 were not made large enough with a high lift cam...there is a chance that they may slip at full vtec lift causing ur rocker to bind potentially destroying ur head..u would need to go with itr/gsr/prelude with a shim ones to make it work...i would go with the prelude ones...they are way cheaper than the rest and they work just as good if not better...dr disco was telling me that the prelude ones have a slightly larger diameter than the gsr/its ones...i believe rlz will modify ur stock ones for like 50 bucks</TD></TR></TABLE>
no idea what you're talking about.
Old Sep 29, 2005 | 08:47 AM
ziich2's Avatar
Blox cam users out there chip in?
Old Sep 29, 2005 | 09:36 PM
ziich2's Avatar
useless
on1xv6
Mar 16, 2012 01:59 PM
'96typeR
Jun 16, 2008 06:03 PM
respectblades
Jun 26, 2003 06:35 AM
Cory man
May 6, 2003 12:58 AM
