vtec probem , did everything , still a shitty vtec - > HELP
i have this problem for 2 months
error code 22 , vtec pressure valve
vtec kicks in and out at high speeds
checked the oil - > enough
opened the valve - > it's all clean and ok inside of it
check the power on cables -> ok
on the first gear it kick ok i can say , but in the 2 , 3 , 4 , 5 gear , almost no vtec
mecanic says i need a new vtec pressure valve ( entire solenoid )
what do you say ? what shoul i do , no ideeas any more
what can it be broken inside the valve ? or not working properly ?
it's true that the piece has 14 years old
, but sounds strage ...
anyone changed the valve because the original was not good and it worked ?
, but sounds strage ...anyone changed the valve because the original was not good and it worked ?
If you use a VAFC the wires could be not hooked up correctly/shorted.
Even if you dont the wiring could be jacked. Or it could actually be correct and el pressure valve could be shot.
