radiator swap..
ok i got a new radiator b/c my old one was gone.. is it as easy as just unbolting the top 2 bolts, unhooking the hoses, and taking it out? or are there hidden bolts?
this is for a 97 base
that's about it, drain it, remove the upper and lower hoses, remove the hose to the overflow can, unplug the fans, unbolt the top two brackets, and lift it out. The radiator just rests on two rubber grommets, so nothing is attached at the bottom.
