Stolen Items - Please Look Out For Them
We got broken in to on saturday night / sunday morning below is a list of some of the items we are missing with some Serials if you happen to come across please throw us a PM and we will get back to it might take a day or two because they stole our computers to thanks for the help guys
-matt
Item Quantity REPL COST Serial Notes
Vertical Door Kits 61 $100,000.00
S10 3" Lower CA 13 $2,600.00
Heat Sheild Gaskets 70 $2,100.00
Replacement Shocks 50 $5,900.00 Lambo Door Kits 60
Replacement Shocks 10 $800.00 Lambo Kits 90
GSR TURBO KIT Full Race 1 $3,000.00
Jenson VM9410 1 $600.00 ? DVD Flip out
Pioneer AVHP6600 1 $1,100.00 DVD Flip out
Dewalt Chop Saw 1 $250.00
Ryobi Grinder 1 $100.00 w020611525
Grinding Wheels 2 $60.00
Power Mig 200 1 $1,500.00 m1030520158 Lincoln From Weiler
Large Argon Bottle 1 $300.00 Lease From Weiler
Argon Regulator 1 $100.00 Weiler
Speedglass 9000xi 2 $600.00 ebay
Metabo Grinder 2 $550.00
Dewalt Grinder 2 $225.00
Horizontal Band Saw 1 $300.00 Harbor Freight
Hypertherm Power Max900 1 $2,400.00 900-007281 Plasma Cutter
Weldma Electrode Grinder 1 $2,000.00 1512 Not Sure on Value
Tap & Die Set 1 $500.00
SataJet Spray Gun 1 $500.00 234565 Performance Paint
Jamb Spray Gun 1 $150.00 Performance Paint
Reface Gun 1 $150.00 Performance Paint
Cup Gun Fiberglass $300.00 Composite 1
Chopper Gun C93 1 $300.00 Composite 1
Spot Weld Cutter Set 1 $125.00 MAC
JitterBug Sander 1 $100.00
IR Flat Line Sander 1 $100.00
IR DA Sander 4151 1 $150.00
Dewalt Hammer Drill 1 $250.00 608035
Dewalt Sawall 1 $200.00 997865
Dewalt Cordless Light 1 $100.00 519605
Dewalt Cordless Saw 1 $150.00 9107
Metric Reversible Gear Wrench 1 $175.00
Standard Reversible Gear Wrench 1 $175.00
Stubby Metric GW 1 $100.00
Stubby Standard GW 1 $100.00
Craftsman Wrench Set 1 $250.00 43 Piece
Craftsman Screw Drivers 1 $100.00
Craftsman File 1 $100.00
Snapon Needle Nose Pliers 5 $400.00
Snapon Adjustbale Joint 2 $200.00
Snapon Locking Plier Set 1 $100.00
Snapon Scanner 1 $2,000.00
Snapon Car Upgrades 1 $1,800.00
Snap Timing Light 1 $350.00
snapon compression Set 1 $250.00
Snapon Vaccum Pressure 1 $175.00
Snapon Cylinder Leakage 1 $300.00
Snapon Test Leads 4 $200.00
Snapon Multi Meter 1 $250.00
Snapon Airbag Reset 1 $500.00
Snapon Tool Chest 1 $7,000.00 Large
Snapon Tool Chest 1 $1,200.00 Small
Snapon Air Hammer 1 $475.00
Snapon Fuel Pressure 1 $250.00
Snapon Refractometer 1 $175.00
Snapon AC Tester 1 $900.00
Snapon AC Gauges 1 $375.00
SNAPON Torque Wrench 1 $250.00 1/4
SNAPON Torque Wrench 1 $300.00 3/8
SNAPON Torque Wrench 1 $375.00 1/2
SNAPON DRILL BITS Letter 1 $130.00
SNAPON DRILL BITS Metric 1 $150.00
SNAPON DRILL BITS Standard 1 $150.00
Impact Swivels SNAPON 1 $400.00 3/8 STD Short
Impact Swivels 1 $400.00 3/8 STD Long
Impact Swivels 1 $400.00 3/8 METRIC Short
Impact Swivels 1 $400.00 3/8 Metric Depp
Impact Swivels 1 $400.00 1/2 STD Short
Impact Swivels 1 $400.00 1/2 STD Long
Impact Swivels 1 $400.00 1/2 Metric Depp
Impact Swivels SNAPON 1 $400.00 1/2 Metric Short
GP "Impact Sockets 1 $130.00 3/8 STD Short
GP "Impact Sockets 1 $130.00 3/8 STD Long
GP "Impact Sockets 1 $130.00 3/8 METRIC Short
GP "Impact Sockets 1 $130.00 3/8 Metric Depp
GP "Impact Sockets 1 $130.00 1/2 STD Short
GP "Impact Sockets 1 $130.00 1/2 STD Long
GP "Impact Sockets 1 $130.00 1/2 Metric Depp
GP "Impact Sockets 1 $130.00 1/2 Metric Short
NutSetters Sets 2 $275.00
mitutoyo digital calipers $150.00
mitutoyo digital MIC 1 $980.00 0-6"
Brother 2820 FAX 1 $225.00
Kodak Digital Camera 1 $400.00 kctct45243286
Zebra 2844PS Thermal 1 $400.00 63a040600239
HP Laptop 1 $2,000.00 TW21912273
HP A244W Computer 1 $750.00
15 " LCD MONITOR 1 $400.00
Custom Built Computer 1 $2,000.00
HP LASERJET 3300 1 $800.00 cnbj004958
NORDSON SureCoat $3,000.00 SHSSNX08C Powder Coating System
Honda Pressure Washer 1 $500.00
Snapon Wrench Set MET 1 $200.00
Snapon Wrench Set STD 1 $200.00
Porta Jump 1 $125.00
Plastic hammers 2 $100.00
Brass Hammers 2 $75.00
Sledge Hammers 2 $100.00
Torque Stick Set 1 $100.00
IR 1/4 Air Ratchet 1 $100.00
Snapon Nut Driver Set 2 $275.00
Solder Gun 1 $50.00
Soldering Iron $50.00
Grinder Burr Set $200.00
Unibit sets 5 $150.00
Tap Wrenches 4 $100.00
3/4 " Drive Impact $600.00
Portable Band Saw $300.00
Hydraulic Pipe Draw Bender 1 $1,200.00
HB Pipe Bender 1 $150.00
20 TON Hydro Hand jack 1 $50.00
Stinger Dent Puller 1 $450.00
OXY ACL toches with Bottle $400.00 Little bottle Exchange
Battery Booster Jumper 500am $600.00
Slide Hammer 1 $75.00
AN Wrenches 1 $75.00 JEGS
Precision Screw Drivers $30.00
Damage to Couch 1 $1,000.00 Replace Sofa
Window Air Conditioner 1 $300.00
Fix Alarm System 1 $750.00
-matt
Solder Gun 1 $50.00
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h0ndavtec »</TD></TR><TR><TD CLASS="quote">somebody had alot of time to clean you out, mustbeen someone you know</TD></TR></TABLE>
this is true ! **** they cleaned you out , bastards
this is true !
this is true !
Jesus, did someone with a few freight trucks come in and noone notice this stuff?
For the tools and related items, do you have recod of the serial numbers incase you need to prove ownership?
EDIT: Posting this one a few boards I am a member on. Going to get the word out about this
Holy ****! That would have to be an insider. With the amount stolen at the ability to do it swiftly and at the right time. Good luck getting it all back. I'm in AL though, so it's doubtful that any would show up here.
Honestly i think that they took SO MUCH that it will be easy to figure out who did it... as soon as one of many people find out all this stuff the have theyll figure it out... As opposed to just having 1 item missing, tehre is only 1 customer and chances of the 1 customer knowing u got robbed or anything are a lot less.
yo man, it had to be an inside job now think or a second, go for the person you trust the most, and think of places that would have the space to put all that stuff w/in a 50mile radius of where it got stolen, find out of car trucks trailers that were rented w/in 2 weeks of the day of theft, do your research this isnt a job that was done by 2 kids and their moms minivan, this is big and a lot of moves had to made before this happen, and this was definatetly planned. Lie detector test 4 everyone, this is a lot of money, oh and check any carrier ships, sometimes they get shipped out by sea, that means there is records of trailers, that were put in ships, 200k is not joke man! and dont tell any1 what your doing , b/c u cant trust any1
Good luck with that, that's so terrible.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dfoxengr »</TD></TR><TR><TD CLASS="quote">how much was the total asessed value gone?</TD></TR></TABLE>
the items in the list total $170,740.00
(I know a few Excel tricks
that list is from monday its been changed a little bit since then, I just wish that I got the feeling like the police actually care, rather than this job gives me a paycheck every week. its super frustrating, we are going to loose so much money, unable to work for about 5-8 weeks, back on bills and being under insured im prob gonna hang up my belt from the whole scene, Ive considered going and getting a real job and working 9-5.
BTW on a side note the laptop that is missing had a wireless network card a linksys 54mps we have the mac address, can any one here have the resource to track a computer via the mac address if so please contact me thanks
-Matt
-Matt
yes it is possible. but the chances are slim.. very slim..
if u have any idea as to where the **** might be drive around with your wifi broadcaster in your car..
id put the chances at 1%.
but that combined with truck rentals and some investigation might yield something.
Yeah this was def well planned out and organized. To load that amount of stuff must have taken a group of people and detailed plan, look at x-employees, customers who seemed to just hang around.
Who is Mr Robot?
yea, you cant exactly hide all of that **** in just any place... and had to have taken one ******* huge truck and lots of time/ppl to move all of it
