Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
Problem with my engine
Old Sep 28, 2005 | 04:28 AM
fRaZ's Avatar
Default Problem with my engine
Hi, i have a 1.6 EL 2000 and i have swap a B18B in and in the 1/4 my result is 16.3 and when i have checkw ith other people over all it's ok. Does he have someone can help me ?
Old Sep 28, 2005 | 04:56 AM
hypnosisracing's Avatar
Default Re: Problem with my engine (fRaZ)
Holy ****...let me see if i can understand what you said...
The problem you are having is that you have a B18b swap in it and its only running 16's in the 1/4 mile? Thats not a problem...that is about what it should run...they arnt power houses by any means, especially in that chassis. The fact the engine swap still left your car slow isnt a problem with the engine unfortunately for you...its just life with a lowly non-VTEC Bseries.
Old Sep 28, 2005 | 12:10 PM
CompanyFlow's Avatar
Default Re: Problem with my engine (hypnosisracing)
Well, its basically a civic, so he should be running into the 15's at least. Get a compression test done.
Old Sep 28, 2005 | 01:35 PM
Stealx's Avatar
Run a scanner on it too, check fuel delivery and all the basics
Old Oct 4, 2005 | 06:59 AM
fRaZ's Avatar
Well The basic test is already done and all its ok ! So what they can be ? is it my weight ?
Old Oct 4, 2005 | 07:13 AM
Its not fast...but you think it should be. That is the problem.
Old Oct 4, 2005 | 11:37 AM
SiSpopu's Avatar
What cind of tranny are you using?
Where did you get the motor from?
Old Oct 4, 2005 | 01:23 PM
fRaZ's Avatar
I have a Tranny of RS and i have a Exedy Stage 1 and the engine come from USA
Old Oct 4, 2005 | 04:08 PM
All I can say now is that your a shitty driver.
Old Oct 5, 2005 | 09:28 AM
1bad-eg's Avatar
Default Re: Problem with my engine (CompanyFlow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CompanyFlow &raquo;</TD></TR><TR><TD CLASS="quote">All I can say now is that your a shitty driver.</TD></TR></TABLE>I'm thinking the same thing.
chlen
Sep 8, 2016 02:12 PM
Rammy
Aug 23, 2007 06:31 AM
preludejdm
Jun 1, 2004 12:07 AM
