96-98 ek civic Radio blockoff!
Go to your local honda dealer, order for 92 cx, it is the exact same piece, and fits perfect, they also have the antenna block off as well, buy it for 92 cx as well but make sure you get the rubber gasket too cause shape is a little different than stock antenna.
Block off panel radio part# 77230-SM4-G00
Antenna block part# 39152-SR3-A00
Antenna gasket part# 39154-SR3-G01
Antenna block screw part# 90105-SB6-003 (you would need to order 2 of these)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by forcefedish »</TD></TR><TR><TD CLASS="quote">Block off panel radio part# 77230-SM4-G00
Antenna block screw part# 90105-SB6-003 (you would need to order 2 of these)</TD></TR></TABLE>
Don't forget a new pocket next to the block off. the DX (w/ radio) and CX (without radio) ones are kind of different. if you're putting in a block off get the pocket from the CX, it'll look alot cleaner and its only another 10 bucks or so.
CX pocket part# 77253-S01-A00ZA
I like the looks of the CX pocket as well. I have an aftermarket deck in the DIN slot - will the CX pocket clear it or will it only fit if there is no radio in the slot?
SprayinCX
12
Aug 27, 2004 01:50 PM
Johnny Tran
20
Feb 5, 2003 02:44 PM
