Mild All motor set up. what pistons to get?
Old Sep 27, 2005 | 10:42 PM
stockegsix's Avatar
Default Mild All motor set up. what pistons to get?
ok guys, I wanna keep my b18c1 head and block, my mods so far are, skunk2 manifold, skunk2 stage 1 cams, profab header, 2.5" exhaust setup, chipped p28. I will be adding ITR valve springs but dont know what pistons to go with. I still wanna run 91 octane.
shooting for over 200hp to the wheels.
Old Sep 27, 2005 | 10:46 PM
nub.96ek's Avatar
Default Re: Mild All motor set up. what pistons to get? (stockdc2)
USDM ITR...
...that should work fine.
Old Sep 27, 2005 | 10:48 PM
stockegsix's Avatar
Default Re: Mild All motor set up. what pistons to get? (nub.96ek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nub.96ek &raquo;</TD></TR><TR><TD CLASS="quote">USDM ITR...
...that should work fine.</TD></TR></TABLE>
thanks, what compression am I looking at?, also that would be the AO73 right?
Old Sep 28, 2005 | 05:22 AM
CNSK's Avatar
I would go with a standard ctr piston with a thinner headgasket(yields more compression) and arp headbolts. Purchase after market sprockets if you havent already for tuning capabalities. With your chipped p28, I would go ahead and throw in a hondata, you'll be very happy...I know I am...ask any hondata owner. If you have a few hundred bucks left over from change LSD wouldnt hurt....keep the power to the ground.....
http://www.c-speedracing.com/h...c.php
Old Sep 28, 2005 | 09:09 AM
95lstegman's Avatar
Default Re: Mild All motor set up. what pistons to get? (CNSK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CNSK &raquo;</TD></TR><TR><TD CLASS="quote">I would go with a standard ctr piston with a thinner headgasket(yields more compression) and arp headbolts. Purchase after market sprockets if you havent already for tuning capabalities. With your chipped p28, I would go ahead and throw in a hondata, you'll be very happy...I know I am...ask any hondata owner. If you have a few hundred bucks left over from change LSD wouldnt hurt....keep the power to the ground.....
http://www.c-speedracing.com/h...c.php</TD></TR></TABLE>
geez, CTR pistons in a GSR? now we're talking some mad compression! that's over 12:1! don't do that unless you have some HUGE cams. tuning for 93 octane will be long and tedious unless you're very good. for the cam sprockets. as for hondata, it's a very expensive solution to a rather inexpensive problem. all you really need is a dyno tune w/ crome or uberdata if you're a simpler kind of person. as for the LSD,
i can't tell you good it is! easily the best mod for your car. i'd take an LSD and stock engine over your engine + open diff any day! and besides, even if you're not into handling, LSD is still god for the strip. my friend's stock S13 240SX Super-HICAS Edition runs 14.6's constantly with just an intake. i can't get below 15 flat even with the SR b/c i have an open diff.
Old Sep 28, 2005 | 09:52 AM
xplanetearth420x's Avatar
Default Re: Mild All motor set up. what pistons to get? (95lstegman)
i have ctr pistons in my car i love them i would do it and with what u have done to ur car already u will be at 200whp easly
Old Sep 28, 2005 | 10:28 AM
LSTEG96's Avatar
Default Re: Mild All motor set up. what pistons to get? (xplanetearth420x)
200WHP? wow.
yeah...
Old Sep 28, 2005 | 11:14 AM
Kendall's Avatar
Default Re: Mild All motor set up. what pistons to get? (93civicB18C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93civicB18C &raquo;</TD></TR><TR><TD CLASS="quote">ctr pistons are a direct fit in the jdm b18c block? would these be good combined with a JRSC</TD></TR></TABLE>
CTR pistons in a GSR block will yield close to 13:1 compression, not good for boost.
For a mild all motor setup consider some JDM ITR pistons (about 11.3:1 compression) or some PR3 pistons if you want to go a little higher than that.
Old Sep 28, 2005 | 02:23 PM
95lstegman's Avatar
Default Re: Mild All motor set up. what pistons to get? (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">CTR pistons in a GSR block will yield close to 13:1 compression, not good for boost.
For a mild all motor setup consider some JDM ITR pistons (about 11.3:1 compression) or some PR3 pistons if you want to go a little higher than that.</TD></TR></TABLE>
yeah i got about 12.5:1 with a quick calculation, that's why i think it's a bad idea.
and to you:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xplanetearth420x &raquo;</TD></TR><TR><TD CLASS="quote">i have ctr pistons in my car i love them i would do it and with what u have done to ur car already u will be at 200whp easly</TD></TR></TABLE>
what the heck? i don't know what you did . . . maybe you bought pistons and they substituted ITR pistons for CTR pistons . . . or maybe you run 110 octane daily . . . or maybe you've got a great tuner who retarded the heck out of your ignition maps . . . or maybe you have HUGE cams and don't have to worry so much . . .
Old Sep 28, 2005 | 08:44 PM
stockegsix's Avatar
thanks, TTT
Old Sep 28, 2005 | 09:13 PM
Chriz's Avatar
ctr
Old Sep 28, 2005 | 10:02 PM
fergy016's Avatar
usdm itr pistons 10.6:1
jdm itr pistons. 11.3-11.5:1
still streetable with 91octane.
I would go with the jdm itr pistons myself. I am running a close set-up to you.
Old Sep 28, 2005 | 11:10 PM
kchungb17a's Avatar
Default Re: (fergy016)
USDM ITR: 10.8 with P72 head. I run 'em, I like 'em.
http://technet.ff-squad.com/cr-calculator.htm
Old Sep 29, 2005 | 12:18 AM
JDM_sedan's Avatar
OEM PCT CTR, highest compression, best OEM for all-motor....
Old Sep 29, 2005 | 12:19 AM
mjc1055's Avatar
Default Re: (kchungb17a)
Okay, this whole piston debate thing has been getting out of hand, so many different people saying so many things.. I know that ctr pistons will yield a sky high compression in b16s and gsrs, but what about itr?
I know type r heads are basically built b16s, and that putting a gsr head on a b18c5 block will raise the compression, and if you put an itr head on a gsr you'll lose compression.. but i dont know how much. since the stock compression ratio of a usdm itr is about 10.6:1, and putting those pistons in a gsr will make 10.8:1, theres only a .2 difference between the heads? I would've thought it would be more than that, but im definately not contradicting anybody here.
Old Sep 29, 2005 | 01:45 AM
JDM_sedan's Avatar
Default Re: (mjc1055)
you are wrong on your whole theory, you got it all backwards fool
Old Sep 29, 2005 | 04:47 AM
95lstegman's Avatar
Default Re: (JDM_sedan)
2 people have already posted c/r calculators. how do you not get it? go to the c/r calculators (either one is fine) and use it!
Old Sep 29, 2005 | 06:50 AM
stockegsix's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fergy016 &raquo;</TD></TR><TR><TD CLASS="quote">usdm itr pistons 10.6:1
I would go with the jdm itr pistons myself. I am running a close set-up to you.</TD></TR></TABLE>
what pistons, are you using? JDM ITR looks lovely.
correct me if Im wrong
A0-p73 = usdm itr
00-p73 = jdm itr
Old Sep 29, 2005 | 09:08 AM
95lstegman's Avatar
Default Re: (stockdc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stockdc2 &raquo;</TD></TR><TR><TD CLASS="quote">what pistons, are you using? JDM ITR looks lovely.
A0-p73 = usdm itr
00-p73 = jdm itr</TD></TR></TABLE>
you are not wrong, and i agree, JDM ITR looks nice as do PR3's (US B16A). the ITR pistons however have the lubricant on the skirts. i forget what it's made of but i would swear it was something about teflon. P30's are a bit much i think, yielding about 11.6:1 in a GSR.
Old Sep 29, 2005 | 09:55 AM
redGSRguy's Avatar
Default Re: (95lstegman)
Looks like I'll be going o/s jdm itr when I finally have the money to pay someone to rebuild my engine. Can you run the stock gsr rods w/o any problems?
Old Sep 29, 2005 | 10:50 AM
kchungb17a's Avatar
Default Re: (redGSRguy)
I'd say the question is how close do you want your engine to blow up mode? I know tons of people use CTR or P30 pistons and have no problems, but the truth is with such a high CR and no tuning, you could very well blow something up, which is cool when it's not your engine.... If you do use them, maybe switch to a PR3 head.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_sedan &raquo;</TD></TR><TR><TD CLASS="quote">you are wrong on your whole theory, you got it all backwards fool</TD></TR></TABLE>
Uh, no, he's got it right.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95lstegman &raquo;</TD></TR><TR><TD CLASS="quote">
...the ITR pistons however have the lubricant on the skirts. i forget what it's made of but i would swear it was something about teflon....</TD></TR></TABLE>
I believe the piston side skirt coat on Type R pistons are molybdenom
Old Sep 29, 2005 | 10:54 AM
95lstegman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kchungb17a &raquo;</TD></TR><TR><TD CLASS="quote">I believe the piston side skirt coat on Type R pistons are molybdenom</TD></TR></TABLE>
yeah i don't know what it's made of. i'm sure it's not Mo but it might be some Mo compound. i just thought teflon made sense or something and it's black and takes high heat.
st9vex
64
Jun 5, 2012 08:11 AM
zexxbo
54
Dec 29, 2007 07:05 AM
wmertz187
Jan 28, 2006 06:37 PM
Bserieskllr
28
Jan 5, 2005 05:09 AM
geminis2k
Jan 16, 2003 12:11 PM
