how to install eletrical oil temp and press gauges
on the oil temp can i put it into the oil drain hole??? will the sender piece fit??? or do i have to redrill a new hole??? and how do i install the oil press? is there a good site to find out how to install??? i went to autometer but they dont tell u where to hook it up too?? i have a 94 gsr... and there both electrical gauges...
[Modified by SPOON_BeIgHtEeNsEe, 9:16 PM 3/2/2002]
I have the same question, but I will suspect that the question will be better answer at the Tech Forum
thanks for the help.... does anyone know how to install the oil temp?? and where can i get these other parts??? lowes???
what could be more appropriate? electric or mechanic for...
oil pressure?
coolant temp?
fuel pres?
I am assuming electric for fuel pressure (not crazy about the idea of a pressurized fuel line in cabin), and i'm stuck on what to use for the other two. Which type of (autometer) gauage would be more precise/accurate with quicker feedback?
oil pressure?
coolant temp?
fuel pres?
hummm, will someone second that suggestion or tell me otherwise? i'll be ordering online tomorrow...
one other question...
brand... what brand gauge would be the most accurate? autometer has some nice prices
sorry bro but ur off the topic... can anybody help me out here... i ready too install... do i have the weld the oil pan for oil temp??? lmk thanks
There have been many posts on installing oil pressure (and similar) gauges here before. I even drew up a diagram on the adapters and fittings needed to do this.
If you want to install more than one gauge, then use multiple Tees attached to each other (mounted to the firewall). For every one Tee you add, you gain another port for gauges.
Use the search.
Use the search.
cyang08
Apr 17, 2006 09:03 PM
SPOON_BeIgHtEeNsEe
Mar 4, 2002 05:24 PM
SPOON_BeIgHtEeNsEe
Mar 3, 2002 05:22 AM
