squeeking steering wheel
Old Sep 27, 2005 | 10:12 PM
b18c-1's Avatar
Default squeeking steering wheel
hey, ive tried searching nothings come up, i was wonder wats up with my steering wheel everytime i do lik a turn great then 90 degrees it makes the squeeking noise from behind the steering wheel any one have an idea wat it is, i've alreadi tried filling up power steering
Old Sep 28, 2005 | 04:18 AM
suzawa94's Avatar
Default Re: squeeking steering wheel (b18c-1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c-1 &raquo;</TD></TR><TR><TD CLASS="quote">hey, ive tried searching nothings come up, i was wonder wats up with my steering wheel everytime i do lik a turn great then 90 degrees it makes the squeeking noise from behind the steering wheel any one have an idea wat it is, i've alreadi tried filling up power steering</TD></TR></TABLE>
possible the universal joints in the column need lubrication
Old Sep 28, 2005 | 04:33 AM
Backk InTheDA's Avatar
I hate everything
Default Re: squeeking steering wheel (suzawa94)
I had this problem, but it was more of a knocking/rattling noise. Anyways, right behind the wheel where it connects to the hub, there is a little ring, its not connected all the way around, meaning, the metal ring is not complete, try moving that around, like sliding it around, thats what was causing mine to act up.
hth
Old Sep 28, 2005 | 11:56 AM
b18c-1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suzawa94 &raquo;</TD></TR><TR><TD CLASS="quote">
possible the universal joints in the column need lubrication</TD></TR></TABLE>
where are these universal joints?
Old Oct 1, 2005 | 08:20 PM
suzawa94's Avatar
nevermind, if the universals were bad they would clunk, not squeak. anyway, there is a column bearing behind the steering wheel. actually the combination switch (turn signals, wipers) sits right on top of it. it's kinda a bitch to get to since you have to remove the steering wheel and clockspring assembly. i'm refering to my 96 service manual. hope that helps..........
Old Oct 1, 2005 | 08:48 PM
PnoyJeff's Avatar
had this problem wheni first got my car....it magically went away after a week or so................................................ .............................
Ur 2 Slow 4 J
Nov 1, 2015 02:25 PM
civicdelsol33
Dec 6, 2011 05:09 AM
stevescivic
Feb 17, 2008 06:31 AM
Damon Reeves
Dec 26, 2007 03:51 PM
RuskeR
Oct 30, 2002 05:59 PM
