2001 honda accord stud 4lug
Old Sep 27, 2005 | 09:47 PM
JDM_S2K's Avatar
Default 2001 honda accord stud 4lug
hi all i have a 2001 honda accord two door i need a diagram on how to change the front right lug stud and diagrams help pionters is greatly appriciated thansk all for big digrams please email too spoonsprts@yahoo.com once again thanks
Old Sep 28, 2005 | 05:11 AM
JimBlake's Avatar
Default Re: 2001 honda accord stud 4lug (JDM_S2K)
You might need to press the hub out, which usually destroys the wheel bearing. Here's what to try...
Take off the caliper & brake rotor. The studs (#20) are pressed into the hub (#3). Some years or some models, you can spin the hub to position the stud so you can press it out. Look for a cut-out in the steering knuckle where the stud can go. Most(?) Hondas don't have that, so you gotta do the wheel-bearing job.
You can take the steering knuckle out of the car, & take it to a shop with a bearing press...
Railroader
Feb 12, 2017 11:30 AM
soph020403@yaho
Apr 6, 2016 02:56 AM
tubular031
Apr 27, 2008 12:17 PM
Old Skool
Feb 21, 2003 12:13 PM
