rear brake pad replacement prob..ideas?
Old Sep 27, 2005 | 09:08 PM
djbrandonr's Avatar
Default rear brake pad replacement prob..ideas?
so heres the issue.
Ive changed brake pads before w/o any probs. Last time I changed the rear pads was 2 years ago almost and no probs. So today I started the project DS first. Now usually I use a C-clamp to compress the piston, but turning it w/ a screwdriver clockwise seemed to work best(kinda like it was threaded almost). Put everything back together, caliper went on snugger like usual and moved on to the PS.
This time I had to compress it w/ the c-clamp (it was a bitch), the caliper was super fricken tight and eventually I couldnt even get the lower caliper bolt to line up and was pressed for time so I threw the 2 best old pads from both sides (yes I used the best propper inner and outer pad too) back on. Caliper slipped on fine, bolts lined up and I was off to work.
Now work is ony a 5 mile drive down the highway and my car felt kinda sluggish. When I parked the car smelled funny and noticed the brakes were mildly smoking and smelling as if I had driven w/ the e-brake partially engaged. Ebrake hasnt been engaged/used since before I started this project. I dont know what went wrong this time, but maybe someone else has some ideas or experiance w/ this. The only thing I can think of is that I put the shims on the new pads from the old ones like I always have and maybe if I take them off it'll allow that little fraction more of space. Heres a pic ot the new and old. Whatcha think??
The one on the left (inner) has a mini shim but the othe one doesnt. I put theones that have always been w/ the car on both..
Old Sep 27, 2005 | 09:19 PM
ed_1's Avatar
Default Re: rear brake pad replacement prob..ideas? (djbrandonr)
Well you have to turn the star looking thing on the piston to the right, that way the piston would go in, cause i had that same problem too, you could use something to do it, u need a special tool, but u could use like needle nose pliers for example to turn the threads that i'm telling to the right. I remember i struggled until my teacher told me what i had to do.
Old Sep 27, 2005 | 11:30 PM
phateless's Avatar
i wonder if the uneven pressure from having 2 new pads and 2 old pads would have anything do with that...i say get the new pads in asap and then see what happens
Old Sep 28, 2005 | 09:09 AM
djbrandonr's Avatar
Default Re: (phateless)
yeah but the DS is all new, and the PS was just the 2 best used ones.
R_ACE1
12
Aug 16, 2009 12:53 PM
CRexcellence
Jun 5, 2007 12:49 PM
vidanator
Jul 21, 2005 12:07 PM
IntegraGSR23
Jan 9, 2003 04:59 PM
