WEIRD WHISTLING NOISE...94 CIVIC SI
OK, HEY GUYS, KINDA NEW TO THE SITE AND CAR STILL BUT I KNOW THIS AINT A NORMAL NOISE....
94 CIVIC SI, AUTO, 2DOOR COUPE.....TIMING BELT AND TUNE UP JUST DONE.....
SO, NOISE....HAPPENS WHEN CAR IS WARMED UP,
COMMON AT IDLE IN DRIVE (AT DRIVE THRU'S), NEUTRAL, PARK. IT'S A LOUD ENOUGH NOISE THAT SOMEONE OUTSIDE THE CAR 15 FEET AWAY COULD HEAR IT AND IT LASTS FOR ABOUT A SECOND OR 2, THEN STOPS, AND RETURNS..... APPLYING THE BRAKES CAUSES IT TO STOP FOR A SECOND....AND THEN USUALLY IT COMES BACK..
HOWEVER, THE COOLING FAN MAKES IT GO AWAY ALL TOGETHER WHEN IT'S IN A CONSTANT PISSY MOOD....
GOING BETWEEN PARK AND REVERSE CAN CAUSE IT FOR A SPLIT SECOND
AND WHEN PARKED, TURNING THE WHEEL EITHER DIRECTION CAN CAUSE IT.
I HAD A SHOP DO THE TIMING BELT, THEN HONDA REDID IT.....LONG STORY INVOLVING MY ENGINE PINGING AND CAM TIMING BEING OFF 3/4 TEETH...
BATTERY IS AT 14.2 VOLTS.....
ANY HELP WOULD BE MORE THEN GREATLY APPRECIATED...
