front and rear control arms didnt fix my suspension issues...
Old Sep 27, 2005 | 06:33 PM
reedwilcox's Avatar
Default front and rear control arms didnt fix my suspension issues...
well i just finished putting new front and rear lower control arms on my 2000 accord and
those were the only visibly bent pieces i had after being run into a median at 70....and i dont know wat to do now....i took it 2 have it aligned thinking that mite do it...but they said nope....i mean its driveable...but i use that term loosley...any help would b appreciated
Old Sep 27, 2005 | 07:03 PM
P_Adams's Avatar
Default Re: front and rear control arms didnt fix my suspension issues... (reedwilcox)
You may have twisted the lower front frame rails (numbers 21 and 23 in the illustration I've provided. This is where your lower control arm mounts and would be one of several areas which would deflect if the impact was hard enough.
http://www.hondaautomotivepart...KHEAD
Unfortunately, to properly check for this condition, it's got to be checked on a frame fixture machine (Guide-chart) or the tried and true method of jack stands, tape measures and the factory specs to compare against. In effect, they check for the front end to be square and a correctly aligned platform to which everything else in attached.
Unless you've access to the specs, you're at the mercy of your local body shop. An Alignment shop will neither have these specs, nor the willingness to get involved.
When your alignment shop gave the "thumbs Down" did they mention a problem with just the front, the rear or both?
P
SPOOLINmatt
Suspension & Brakes
21
Dec 22, 2010 03:40 PM
So Cal So Boosted
Jun 11, 2007 07:40 PM
