96-98 cluster wiring isn't different from 99-00 is it?
Try checking all the fuses, may have a blown one either under the dash or there may be one under the hood (not sure if there is one under there). Does everything else work properly like the speedo and other gauges?
Yeah, thats like when I bought my car and found out that when the person before me installed there radio they cut the factory harness instead of spending $7 on one from a radio shop. Have you tried using another dimmer switch? Maybe it went bad when they cut the wires.
Caoboy
16
Oct 1, 2004 01:15 PM
