Is the f23 tranny a direct drop in a f22b1 engine?
Old Sep 27, 2005 | 04:57 PM
hondaracin24's Avatar
Default Is the f23 tranny a direct drop in a f22b1 engine?
Is there anything that needs to be changed or added in order for it to be a direct fit? Thanks.
Old Sep 28, 2005 | 01:45 PM
Default Re: Is the f23 tranny a direct drop in a f22b1 engine? (hondaracin24)
anyone?
Old Sep 28, 2005 | 02:26 PM
stinker504's Avatar
I know the F22 tranny swaps into the F23, so I would assume it would work in reverse.
Old Sep 28, 2005 | 03:41 PM
1990hondaHF's Avatar
Default Re: (stinker504)
Are you swapping the f23 tranny out of the car or into the car? I'm confused a bit.
Old Sep 28, 2005 | 04:09 PM
Default Re: (1990hondaHF)
I want to swap out my f22 tranny for an f23.....
Old Sep 28, 2005 | 04:29 PM
raceACCORDingly's Avatar
yes but i dont know if the f23 vss is the same
Old Sep 28, 2005 | 05:34 PM
Default Re: (raceACCORDingly)
the shift linkage is odd on my 98 accord...migt need some mods...I could be wrong though.
Old Sep 29, 2005 | 01:29 PM
Anyone else?
Old Sep 30, 2005 | 02:09 PM
Default Re: (hondaracin24)
Man i didnt think this was such a technical question. I know someone has done the swap before.....
Old Oct 1, 2005 | 03:51 PM
Old Oct 2, 2005 | 06:21 AM
YeuEmMaiMai's Avatar
auto or manual?
Old Oct 2, 2005 | 07:29 AM
Default Re: (YeuEmMaiMai)
Manual
Old Oct 2, 2005 | 10:19 AM
SuperSlow's Avatar
It will bolt up perfectly if that is what you are asking. So will any of the H-series trannies.
Old Oct 2, 2005 | 06:19 PM
Default Re: Is the f23 tranny a direct drop in a f22b1 engine? (SuperSlow)
So nothing needs to be changed such as linkages and stuff like that?
Old Oct 3, 2005 | 04:09 AM
accord387's Avatar
nope, just put the f23 one in. Is your f22 tranny messed up and the f23 is good to go?
Old Oct 3, 2005 | 03:21 PM
Default Re: (accord387)
The f22 tranny works alright. It can be a little rough at times in second gear since its been grinded a few times in the past. I mainly want the f23 because of the better gear ratios. I dont have one right now but now that I know its a direct drop in Ill be looking into one soon. Thanks.
Old Oct 4, 2005 | 09:40 AM
accord387's Avatar
whats the gear ratios of a f23 transmission?
Old Oct 10, 2005 | 04:08 PM
Im not sure...all I know is that the f23 transmission has shorter gears where the f22 has longer ones for better fuel economy.....
Old Oct 10, 2005 | 05:13 PM
accord387's Avatar
you sure? i dont see why the f23 would have shorter gears with more torque and also not being used for a performance application
Old Oct 10, 2005 | 06:09 PM
Im pretty sure. All hondas are made to have good fuel economy. Some transimissions are just more performance oriented than others. In this case the f23 transmission has a faster 0-60mph time by a little more than a second if Im not mistaking.
My friend and I had a drag race one day. He has a 98 Accord 4cyl and I have a 95 EX. His was basically stock other than an intake whereas mine has quite a few mods to it other than your basic bolt ons. We tied like 3 times out of the 4 times we raced. This is part of the reason that I want the f23 tranny, that and I think mine could use a rebuild after 155k.
Old Oct 10, 2005 | 09:11 PM
accord387's Avatar
^ both of you go 20mph/40mph/60mph/80mph and see what rpm you are at in corresponding gears, thats an easy way to see how dramatic of difference there is... The f23 may be like the h23 transmission i guess.
Old Oct 13, 2021 | 05:40 AM
Jason96Accord's Avatar
[QUOTE=hondaracin24;17985479]Im not sure...all I know is that the f23 transmission has shorter gears where the f22 has longer ones for better fuel economy.....[/QUOTE
hey did you ever do the swap?
joshabber
Honda Civic (2001 - 2005)
Jun 1, 2015 10:03 PM
B20TRIZ
Jan 19, 2009 05:08 PM
Civic4less
Sep 4, 2004 07:15 PM
self_made
Dec 18, 2002 10:31 PM
hybridcrx
Feb 28, 2002 04:38 PM
