searched.... how to keep secondarys open on c1 mani....
Old Sep 27, 2005 | 04:41 PM
guywitaDA's Avatar
Default searched.... how to keep secondarys open on c1 mani....
I just got a 00 gsr head and i want to eliminate the secondarys.... I know buy a new mani... but funds are tight and i want to get it together.....
Old Sep 27, 2005 | 06:33 PM
CARMA_626's Avatar
I drive a G35, it's silver, surprised?
Default Re: searched.... how to keep secondarys open on c1 mani.... (guywitaDA)
there should be a plunger or something on the right side of the intake runners. you'll have to pull it open manually and figure a way to keep it open.
I recommend chewing gum or zip ties.
Old Sep 27, 2005 | 06:53 PM
Nataku's Avatar
Default Re: searched.... how to keep secondarys open on c1 mani.... (carma_626)
i thought there was some reason as to why you shouldn't do this but i can't seem to remember.
Old Sep 27, 2005 | 07:01 PM
jdmsiR20's Avatar
Default Re: searched.... how to keep secondarys open on c1 mani.... (Nataku)
its easy as pie!!
simply, remove the vacuum line from the dashpot on the manifold (ill look for a pic).
the secondaries are NORMALLY OPEN....
when vacuum is created (motor on), the valves close.
the guy who i bought my cams from suggested i try it until i got i got a single runner manifold.... try it out, car feels different. no torque down low, but a good rush up on top. faster than with the manifold in stock form? i dont think so.... worth a shot tho
Old Sep 27, 2005 | 07:07 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nataku &raquo;</TD></TR><TR><TD CLASS="quote">i thought there was some reason as to why you shouldn't do this but i can't seem to remember.</TD></TR></TABLE>
The reason not to do this is basically that there will be no benefit, and low-end power will suffer. If you still really want to do it, just unplug the vacuum line from the actuator and plug it.
Old Sep 27, 2005 | 07:10 PM
Padawan's Avatar
Darth ModerVader
Default Re: searched.... how to keep secondarys open on c1 mani.... (jdmsiR20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmsiR20 &raquo;</TD></TR><TR><TD CLASS="quote">try it out, car feels different. no torque down low, but a good rush up on top. faster than with the manifold in stock form? i dont think so.... worth a shot tho </TD></TR></TABLE>
There won't be any gains in the upper power band since the butterflies would already be open anyway, and as you stated, low-end power will suffer. Keep in mind that Honda designed the system like it is for a reason.
Old Sep 27, 2005 | 07:12 PM
jdmsiR20's Avatar
Default Re: searched.... how to keep secondarys open on c1 mani.... (Padawan)
^^yep... just made it sound better
may i suggest the AEBS manifold?.... only $180ish shipped.... im actually waiting to put it on myself
Old Sep 28, 2005 | 05:19 PM
guywitaDA's Avatar
this is just a temorary fix.. im going to purchase a mani later.. thanks for all the feedback.. i wont remove the flaps or anything i will do like you said and just keep the vaccum unplugged..
Old Sep 28, 2005 | 05:37 PM
B18C_DD's Avatar
unless you have some cams or headwork there is no point in doing this. The gsr manifold is meant for mid range torque........people who get single stage manifolds with stock ecu's, no form of tuning, or no headwork, don't realize that it is only hurting them!
Get some cams (itr's are perfect) and a manifold and a vafc and that will be perfect. Short on money.....then save. No point in hurting your cars performance.
(Not sure if you realize leaving the butterflies open will not help you top end because they would be open anyway in high rpms.)
Old Sep 28, 2005 | 06:51 PM
DAguyLS's Avatar
All you'll be doing is losing low end power.
It does NOTHING for upper rpm power.
So why would you want to do this?
mkeacura
Aug 30, 2013 01:22 AM
a1320honda
Oct 17, 2007 08:00 PM
wytechoppin
Feb 10, 2006 09:07 AM
civtegra_hybrid
Sep 14, 2004 03:32 AM
VNTEC
Jul 13, 2004 06:28 AM
