Rear Washer Nozzle Removal 94-01 Hatchback
Sorry i dont know, but once you remove it what will you be doing with the hole? Weld and fill, or did you find some sort of plug?
I ask becuase i have been think about getting rid of mine also.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator »</TD></TR><TR><TD CLASS="quote">I need to remove it to properly paint the roof. If I just wanted to remove it, I'd shear it and do the body work.</TD></TR></TABLE>
remove the headline and you'll see the tube leading to it:
after you remove the tube I belie you twist and pull up to remove it. I don't have pics of what it looks like but Im sure it's not too hard to figure out.
I got it. Actually, there are tabs on the front and back of the nozzle. I slid credit cards between the rubber grommet and the roof to release these. I dropped the headliner to detach the hose, as the connection to the nozzle would not budge.
Thanks for the input!
