clutch question
Old Sep 27, 2005 | 02:02 PM
blacK_Dc4's Avatar
Default clutch question
hey wassup .. have integra gsr .. jus slapped on an exedy stage 1 clutch kit about 3 days ago .. right now if i have the clutch pressed down on first gear waiting for the light to turn green .. theres this weird noise that goes away when i engage .. anything i should worry about or is this normal ? thanks
Old Sep 27, 2005 | 02:08 PM
Kendall's Avatar
Bleed your clutch. It's probably making slight contact with the pedal pressed (fairly common among aftermarket clutches). It usually goes away with fresh fluid and a good bleeding job.
Old Sep 27, 2005 | 02:10 PM
sooo_slow's Avatar
New User
Default Re: (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">Bleed your clutch. It's probably making slight contact with the pedal pressed (fairly common among aftermarket clutches). It usually goes away with fresh fluid and a good bleeding job.</TD></TR></TABLE>
Old Sep 27, 2005 | 02:19 PM
blacK_Dc4's Avatar
Default Re: (sooo_slow)
thanks for the quick responses guys .. jus wondering if this will cause any problems if i keep driving it like this for a couple of days before i m free to bleed it ? .. thanks
Old Sep 27, 2005 | 09:26 PM
blacK_Dc4's Avatar
Default Re: (blacK_Dc4)
bump
Old Sep 28, 2005 | 09:14 AM
sooo_slow's Avatar
New User
No it shouldnt be too much of a problem, just keep into consideration that your still breaking the clutch in, so you really shouldt be hard on it for about 1000km's..
But the sooner you can bleed it, the better..
GranddaddyPurple
Feb 10, 2008 04:33 AM
-Championship-
Sep 12, 2006 01:01 PM
Integgin
Mar 27, 2005 05:22 PM
Toretto
Aug 1, 2003 02:48 PM
~~~InNeEdFoRsPeEd~~~
Jul 3, 2003 09:20 AM
