Any one have this set up?
Old Sep 27, 2005 | 12:19 PM
spoonEGcivichatch's Avatar
Default Any one have this set up?
The ? i am asking is if any one is running this set up becasue i have my b16b civic type r pistons on the way and i was wondering if the 404 cams form crower will work, and that the valves will clear the pistons on the up stroke. any help is much needed, i need to get this right, and also i am going to be runing this engine with 12.1:1 compression and wondering will i still be able to run pump gas.
b18b block
stock crank
b16b pistons (CTR PISTONS)
stock rods
b18b head
404 crower cams
crower dual valve springs
crower retainers
port poslish
and lts other mods just needed to list these for my ?
thanks
Old Sep 27, 2005 | 03:43 PM
non-VTEC's Avatar
Default Re: Any one have this set up? (spoonEG9civichatch)
you will be fine.......the B18B head has smaller valves than the VTEC head so clearence is not really and issue unless you had the head milled alot.
Old Sep 28, 2005 | 01:17 AM
Default Re: Any one have this set up? (non-VTEC)
thanks
lsturbo*
May 20, 2007 07:54 PM
^AnDre^
Apr 4, 2005 04:11 PM
94si94cx
May 31, 2004 08:22 PM
Em0ne
Mar 22, 2004 02:29 PM
specie
Jan 7, 2004 07:06 PM
