STANDALONE 100% programmable ECU for OBD1
you can add an obd1 > obd2 harness if you like (which was what i did on the 2000 prelude)
works on civics, integras, preludes (with obd2 >1 harness)
This is the called “LINK Engine Management” ECU for Hondas. Comes with software to connect to your LAPTOP via serial cable (included). Perfect for boost applications!
Works for all Hondas with OBD1 civics and integras. OBD2 will need the converter harness (which I also have). I had it on a 97-01 prelude and it read all sensors.
Able to adjust
- Timing (on the fly tuning) in vacuum and boost
- Fuel (on the fly tuning)
- Electronic wastegate
- idle parameters
- closed loop (lambda control)
- launch control
- KNOCK feature (to record knock and reduce timing)
- VTEC controller
- Alarms & limits
- Air Conditioning enrichment controls
- Much more
display
- DATALOGGING!!!!! And able to set markers
- shift light
- displays analog gauges on screen
- displays 2d and 3d map of fuel and ignition
- coolant temp
- MAP
- RPM
- Duty cycles
- Throttle
- Battery voltage
- Much more
FEATURES EQUIVALENT TO HONDATA’S STAGE 4 COMPUTER
easy to use. Reads all stock sensors perfectly. Fits into OBD1 computer case. Uses windows OS. Comes with basemaps, closed loop lambda control.
$675 shipped to you in the continental US obo
$50 for OBD1 to OBD2 harness
$20 for the obd1 ecu case (which is what it fits into)
if you are unsure about anything, ask questions.
PM if interested
Able to adjust
- idle parameters
- launch control
- VTEC controller
- Alarms & limits
- Much more
display
- shift light
- coolant temp
- MAP
- RPM
- Duty cycles
- Throttle
- Battery voltage
- Much more
PM if interested
