1990-1991 Integra non-vtec distributor in B16a, throttle body compatible?
Anyone know if a 1990 Acura Integra 1.8 NON-Vtec distributor and throttle body will fit my first gen b16a1?
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daidilus »</TD></TR><TR><TD CLASS="quote">you will have to cut a leg off the dissy</TD></TR></TABLE>
throttle body will work fine.
From: behind the dumpster, w./your bitch, w./your bitch
throttle body will work, as far as dist.-as long as you can get the timing set you should be ok, it would be a lil ghetto cutting a leg off but if you are on a budget go for it
line up the shaft coupler with the slot in the end of the cam (only fits 1 way) while engine is at tdc. rotate dist. body so a couple legs line up with corresponding threaded holes in head. choose the one that isnt lining up for dismissal. clamp in vise. remove by preferred method (i like air saw). eat pizza, or mashed potatoes w./gravy...... thats satisfaction...
mycvc8u2
Oct 11, 2002 11:21 PM
18, 1991, b16, b16a, body, compatiable, compatibilities, distributor, head, integra, nonvtec, stock, tec, throttle, vtec
