B16a3 del sol starter won't ground any ideas?
Old Sep 27, 2005 | 09:31 AM
Solless's Avatar
Default B16a3 del sol starter won't ground any ideas?
Starter won't ground when installed works fine on the bench but has bad ground when installed
I already tried cleaning the mating surface up buy it didn't help
Thanks
Old Sep 27, 2005 | 09:43 AM
VTIDelSol's Avatar
Default Re: B16a3 del sol starter won't ground any ideas? (Solless)
Just connect a thick ground wire from the starter to the chassis or the common ground on the engine to the chassis. But first check stock ground...take off ground wires and wire brush them and the grounding surface. Might have paint or something on them.
Old Sep 27, 2005 | 09:44 AM
civic_driver's Avatar
tranny to chasis is the starter ground.. make sure the starter makes good contact with tranny and that the tranny to chasis ground is clean and tight
btw, brushing works, but I would just sand down all the paint and even the starter connectors for a cleaner connection
hondachris1994
Aug 15, 2019 03:07 PM
GoBrowns
Oct 3, 2013 02:56 AM
BobbyRodriguez
Nov 16, 2011 05:15 AM
Skeletor
13
Nov 22, 2005 11:03 AM
SOUTHCREX
Jan 8, 2003 08:58 AM
