Vibration while idling
Old Sep 27, 2005 | 09:00 AM
Jesterian's Avatar
Default Vibration while idling
Just had a b16 swapped into my hatch... Everything seems to run great, but the car vibrates a lot when I idle. Not a ridiculous amount, but it's noticable and not smooth. What could I do to smooth this out?
Also, I get a good amount of steering wheel/gas pedal/shift **** vibration when I'm accelerating right around 40-55.. It smooths out at higher speeds. Any advice on that?
Old Sep 27, 2005 | 09:31 AM
aka's Avatar
aka
which mount kit did you use? The lip on the rear crossmember needs to be bent downward sometimes just under the rear mount. If the rear mount sits on the lip of the crossmember it will give a nice vibration.
Old Sep 27, 2005 | 09:32 AM
Jesterian's Avatar
Default Re: (aka)
Hasport mount kit.
Old Sep 27, 2005 | 09:39 AM
Jesterian's Avatar
Default Re: (Jesterian)
Went out and checked the rear mount.. It looks like it clears, but since I didn't pull anything and I just kinda peered down from the side I can't be certain. Any other suggestions?
What kind of vibration would I feel if it didn't clear? Would it be really pronounced and harsh? This vibration just feels like it is idling really low maybe. I can give it some gas and it smooths out. Also, seems like after I run the car for a while it tends to be smoother...
Old Sep 27, 2005 | 10:23 AM
Aphrodavid's Avatar
welcome to the world of solid motor mounts
its normal
Old Sep 27, 2005 | 08:28 PM
Jesterian's Avatar
Default Re: (Braveheart)
... I don't think vibration like that is normal. Especially when it smooths out if I give it gas.
Old Sep 27, 2005 | 08:42 PM
whophlungpoo's Avatar
couldnt u just squirt in some poly. from the hardware store?
i know this might be a little whiskey tango
Old Sep 27, 2005 | 08:43 PM
Jesterian's Avatar
Default Re: (fisherkc)
Dude, is that english? Whiskey tango?
Lol, not trying to be mean, I have no idea what you just posted.
Old Sep 27, 2005 | 09:15 PM
.Grimace's Avatar
footwork mastery
hey with the wheel shake from 40-55mph go check your lug nuts. may sound dumb but maybe you forgot
g-ride-si's Avatar
welcome to hasport. my hcps have little to no vibration. Check the crossmember better though. When you downshift or get on it hard does it clunk any?
Old Sep 28, 2005 | 07:24 AM
Jesterian's Avatar
Default Re: (g-ride-si)
Mmk, the vibration from 40-55 was from underinflated tires... The guy that swapped my engine also swapped my brakes and threw some 16s on there but didn't pump them up to their correct psi. It feels much better now with just slight vibration that I'd expect from this kind of swap. The idle thing though feels like it may be idling too low on the rpms? I don't have a tach installed, so I can't tell. Also, when I start up the car in the morning the first time I hit the gas the pedal sticks, and after that it's alright. Shrug. Any advice?
Old Sep 28, 2005 | 10:12 AM
g-ride-si's Avatar
When i first swapped a b18a it did the same low idle your talking about, then i realized the tps sensor was unplugged so i plugged it in and while i was there took off the eacv and cleaned it really good. Fixed all my idle problems.
silver accord
Nov 15, 2012 10:25 AM
an2ny888
Nov 2, 2006 05:05 PM
Lemonade
Jul 31, 2002 12:05 AM
