Helical (planetary) v. Spur Gears
Old Sep 27, 2005 | 08:23 AM
vinuneuro's Avatar
Default Helical (planetary) v. Spur Gears
Can any of you describe the advantages of helical gears over spur gears? Are they worth the extra cost?
Old Sep 27, 2005 | 11:04 AM
sporkcrx's Avatar
Default Re: Helical (planetary) v. Spur Gears (vinuneuro)
Helical gears only advantage over straight cut is that they are silent. Straight cut can take more power, they dont push away from each other, and are cheaper to produce.
Old Sep 27, 2005 | 01:15 PM
JimBlake's Avatar
Default Re: Helical (sporkcrx)
Also... Planetary gears are something completely different. Planetary gearsets can be cut either way, helical or straight.
Old Sep 28, 2005 | 04:37 PM
superdupervtec's Avatar
Helical gears are so much more superior then the straight cut gear.
They handle more power because the load is distributed over more of a contact area and are also silent.
Only advantages to a straight cut gear is that it reduces chances of having that gearcome out of gear during accel, also why it is used so often in reverse, and are cheap to manufacture.
Also should add, Another advantage to straight cut is that the create less stress on the transmission case.
Modified by superdupervtec at 5:52 PM 9/28/2005
Old Sep 28, 2005 | 11:29 PM
sporkcrx's Avatar
Default Re: Helical (superdupervtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superdupervtec &raquo;</TD></TR><TR><TD CLASS="quote"> also why it is used so often in reverse, and are cheap to manufacture.
Also should add, Another advantage to straight cut is that the create less stress on the transmission case.</TD></TR></TABLE>
That's true, the rest is rubbish.
Old Oct 2, 2005 | 03:01 PM
I know from what everyone says that straight cut gears are stronger but leave out all other factors on loads etc.
One gear vs the other, the helical is a stronger gear.
Which one is stronger on a stock b series transmission, most likely the straight cut because the case isn't the strongest, but if you had a stronger casting that could withstand the loads created by helical cut gears, then the stronger case with helical gears is a stronger tranmission.
This is fact.
Ek9Ace
Transmission & Drivetrain
Dec 13, 2010 12:22 PM
mike93eh2
Apr 13, 2008 08:21 PM
Bense
Welding / Fabrication
16
Oct 26, 2006 04:38 AM
DaX
May 19, 2004 04:31 PM
citanest
Jan 14, 2002 09:40 AM
