st sway bar
Old Sep 27, 2005 | 07:55 AM
pny1981's Avatar
Default st sway bar
So i have a 96 rs integra, and i just got the st sway bar kit. My question is, since my car didnt have a rear sway, will the bar mount up? Or do i need to buy more hardware, ie end links?
Old Sep 27, 2005 | 08:23 AM
Backk InTheDA's Avatar
I hate everything
Default Re: st sway bar (pny1981)
I've heard that a mounting kit is never a bad idea.
Old Sep 27, 2005 | 01:36 PM
94integrals's Avatar
I'm pretty sure your car came stock with a small diameter sway bar (14mm?). The ST kit came with all the hardware, but you have to drill an extra hole on either side for the mounting since the bar is larger. Here is a picture of mine:
Old Sep 27, 2005 | 01:37 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Yeah the ST swaybar comes with mounting hardware that is pretty much identical to a BSQ mount kit.
Old Sep 27, 2005 | 02:08 PM
SilverDC4's Avatar
Default Re: st sway bar (PatrickGSR94)
RSs didn't come with a sway bar.... i don't think, maybe i'm wrong, the only thing you would have to do yourself is do a bit of drilling.
Old Sep 27, 2005 | 04:46 PM
Sam92Teg's Avatar
Default Re: st sway bar (SilverDC4)
I have a 92 RS Teg, and I have a stock rear sway bar on mine, even if it is tiny. How hard is it to go look under the rear of your car and see if there is a bar going across it?
Old Sep 27, 2005 | 04:58 PM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverDC4 &raquo;</TD></TR><TR><TD CLASS="quote">RSs didn't come with a sway bar.... i don't think, maybe i'm wrong, the only thing you would have to do yourself is do a bit of drilling.</TD></TR></TABLE>
yea your kinda wrong, all tegs had sway bars, with the exception on the gen1's....those im not to sure about
Modified by projectTeG at 2:42 AM 9/28/2005
Old Sep 27, 2005 | 05:34 PM
Chewie's Avatar
Default Re: st sway bar (projectTeG)
all the g3 teg had rear sways, they were 14mm with exception of ITRs.
Old Sep 27, 2005 | 07:14 PM
SilverDC4's Avatar
Default Re: st sway bar (Chewie)
my mistake then my friend had an rs with civic lcas sooooo no sway bar
Old Sep 27, 2005 | 07:32 PM
MatHadder's Avatar
I have a 96 integra rs with the st rear sway bar and lower tie bar kit. bolted right in, no problems.
Old Sep 27, 2005 | 10:35 PM
Ckleijne's Avatar
Default Re: st sway bar (MatHadder)
So did you have to drill another hole to make the st bar fit?
pny1981
Suspension & Brakes
Sep 27, 2005 08:39 AM
katb16vo
22
Mar 25, 2004 03:29 PM
WuRKD b16
Mar 3, 2004 02:37 PM
Vinceg99
Jan 10, 2003 10:56 AM
