Color of the Crank Case postion wire?
Old Sep 27, 2005 | 07:17 AM
Civicman86's Avatar
Default Color of the Crank Case postion wire?
What is the color of the wire on a obd1 dizzy? Wht about the color on obd2 wiring harness?
Old Sep 27, 2005 | 02:55 PM
kodirtysi's Avatar
Default Re: Color of the Crank Case postion wire? (Civicman86)
BUMP
Old Sep 27, 2005 | 03:14 PM
Civicman86's Avatar
Default Re: Color of the Crank Case postion wire? (kodirtysi)
I found out the answer to this all. KOdirtysi if you need and diagram let me know. Im going to make it out tonight.
Old Sep 27, 2005 | 03:45 PM
Echo7847's Avatar
obd1 vtec - terminal b (b15) blu/grn
terminal f (b16) blu/yel
obd2 vtec - terminal 2 (c2) blu
terminal 6 (c12) wht
terminal x = location on dist plug
(xx) = ecm connector/pin
dutchman5
Nov 11, 2005 08:31 PM
SiRRedneck
14
Apr 28, 2005 07:11 PM
Audipwr1
May 12, 2003 01:00 PM
