need help with tranny!!!
i got a b16 swap done into a da integgy.... the only thing is, the clutch is not engaging!! i dont know why, but we swapped flywheels, clutches, cables, forks, adjusted the cable, and it still doesnt want to engage... now the trans is a j1 trans... is that the right trans to be using on my da with a b16a?? im tired of taking off the trans on and off, can someone help me out?? oh, and no, the clutch isn't in backwards. someone asked me that but i dont know how the fukk u gonna put a clutch in backwards... any help guys!?!
this happened to me where it will start but wont move when i put a new clutch net pressure plate in because it is a hydro pressure plate(it is thicker) most likely so you wont be able to engage or disengage the clutch send yours back and say you need a plate for cable tranny
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dravesef »</TD></TR><TR><TD CLASS="quote">this happened to me where it will start but wont move when i put a new clutch net pressure plate in because it is a hydro pressure plate(it is thicker) most likely so you wont be able to engage or disengage the clutch send yours back and say you need a plate for cable tranny</TD></TR></TABLE>
i got a cable pressure plate on... i know that for sure.. cause i used the pressure plate off of my homie's ef??
From: behind the dumpster, w./your bitch, w./your bitch
i have never heard a diff between hydro and cable pressure plates in the paast 7 years, exedy does not differrentiate between the two.
jwbnavy
12
Dec 2, 2007 06:36 PM
vegaskurt
Apr 14, 2005 10:46 AM
