Any info on F20B motor would be GREAT
Old Sep 27, 2005 | 01:12 AM
jase ek's Avatar
Default Any info on F20B motor would be GREAT
hey there ppl
im chasing some info on the F20B motor.. like wiring diagram and stuff.. im doin a conversion into my ek and much help is needed
thanks
Old Sep 27, 2005 | 08:46 AM
JDogg's Avatar
Default Re: Any info on F20B motor would be GREAT (jase ek)
convert it to obd1 and pretend like its a h22.
you need obd1 h22 distributor, you need upper 1/2 of h22 intake manifold and iacv, you will need to change the injector clips on the eg wiring harness.
Old Sep 27, 2005 | 08:50 AM
JDogg's Avatar
Default Re: Any info on F20B motor would be GREAT (JDogg)
you will also need an obd1 h22 alternator, the obd2 f20b alternator has a different plug.
you will need to change the driver side (timing belt side) engine mount with one from a h22.
thats all i can think of right now. just do it like a normal swap once you change those parts. modify the wiring harness from the civic to fit the motor. if you change everything i said it will plug right in. you can do it w/the f20b dizzy and alternator, but it will require changing the plugs on the civic wiring harness.
Old Sep 27, 2005 | 10:04 AM
blundar's Avatar
he said EK not EG
Only thing you need to change is the upper half of the intake manifold, iacv, etc.
Old Sep 27, 2005 | 11:18 AM
JDogg's Avatar
Default Re: (blundar)
ah.. woops.. lol, reading is key to life
yeah, what blundar said
Old Sep 27, 2005 | 01:47 PM
jase ek's Avatar
cheers.. yea im try to get the f20b into the ek.. so i need a h22 intake mani ?
Ryan Moase
Jan 1, 2016 10:20 PM
EKHWhat
Oct 16, 2006 01:12 PM
95accordh22a
Dec 4, 2004 06:25 PM
Adam.
Dec 23, 2003 04:01 AM
