vtec cyliniod gasket/filter keeps breaking
Old Mar 2, 2002 | 05:49 AM
rice4life's Avatar
Default vtec cyliniod gasket/filter keeps breaking
i got jdm sir swao and the gasket with a screen that goes between the vtec cyleniod and block keeps breaking and leaking oil. the original one on there have a very slow leak, so i replaced it with a new one and it leaked again the next day, i replaced it again and it leaked again, both had a small tear in the same spot. so i replaced again and it lasted about 3 weeks until 4 days ago it leaked again. i thought didn't install it right because 3 have broken in a month, so i took it to a Honda dealer to have them put it on. They are one of the best Honda dealer in the state, so i know that they did it right. but it just broke again today. i have asked everyone around the area that do engine swap and work on Hondas and no one have seen this happened before. one guy did mention that maybe my oil pressure regulator is not working properly and my oil pressure is too high. what do you guys think.
Old Mar 2, 2002 | 01:26 PM
Some Gook with a DC2's Avatar
Default Re: vtec cyliniod gasket/filter keeps breaking (rice4life)
i dunno if this helps but how much oil do you have? full, low, or between? im asking you this because if your dipstick is full or past the full mark, you can blow your main seal (main oil seal? dont remember what its called) because of pressure from running the engine. thats why its good to run in between full and low so the pressure doesnt blow a seal. im no sure but maybe your car has too much oil and it breaks/tears in that spot because of pressure from high rpm's like the main seals do.
Old Mar 2, 2002 | 02:19 PM
rice4life's Avatar
Default Re: vtec cyliniod gasket/filter keeps breaking (Some ****)
oil level is just right. there is no crack or sharp edges that would cut the seal either.
Proud Virginian
Jun 20, 2022 06:59 AM
93h22a1vtec
Dec 15, 2005 07:03 PM
rice4life
Mar 2, 2002 10:27 AM
rice4life
Mar 2, 2002 06:12 AM
