Anyone using the specialty Adj Ball Joint Camber Kit?
Since I installed this kit with the Ground Controls and KYB AGX I am getting a weird sound whenever I take a hard turn. I think the bolt on the upper side of the Ball Joint is hitting the upper frame of the car (where the engine strut bar is mounted). I installed the kit that corrects up to 1.5 degrees front and I am running them now with about -0.6 degrees front and -0.4 degrees rear. I have about 2 finger gap in the front with 205/50ZR15 tire. Anyone else having this problem? Is it safe to keep driving with that?
Orlando
[Modified by Racer, 6:49 AM 3/2/2002]
Orlando
I bought them on a camber kit groupbuy. Here is the link to the specialty site. You should be able to get them anywhere specialty products are sold. I bought these because they do not squeak like the older style ones. In addition to camber you can also adjust convergence with these kit.
http://www.specprod.com/TEMP_DIR/TEMP_67120.HTML
Hope this helps,
Orlando
Hope this helps,
Orlando
jdmeg6honda
Suspension & Brakes
Apr 16, 2011 10:25 AM
LagunaSecaEG
11
Sep 3, 2006 07:01 AM
