zc crank pulley
Old Sep 26, 2005 | 06:45 PM
speedd2286's Avatar
Default zc crank pulley
can someone post a pic or explain where TDC is labled on the crank pulley...i guess the belt wasnt tight enough and it just jumped the teeth opn the cam gears...so now i need to set evcerything back to TDC
Old Sep 26, 2005 | 06:57 PM
speedd2286's Avatar
Default Re: zc crank pulley (speedd2286)
bump someone plz...need to get the car running again
Old Sep 26, 2005 | 07:15 PM
messeduprex's Avatar
yo need to take the pully off yith the tinig cover once of you will see a white lin on the cog that the belt rides on the best thing to do is take the #1 spark plug out stick a long screwdriver down rotate the crankshaft till the #1 piston is @ tdc then make sure the line on the cog is lined up with the arrow on the block but also remember to check to see if the cam(s) are also alignd properly
Old Sep 26, 2005 | 07:36 PM
speedd2286's Avatar
Default Re: zc crank pulley (messeduprex)
ok thanks for the help
Old Sep 26, 2005 | 08:13 PM
MONSTERZC's Avatar
its the 4th mark on the pulley it will look something like this ''' '
fourthaxis
Jan 5, 2013 06:57 PM
DAintegraGSR
Aug 30, 2009 06:34 PM
daylon1650
Feb 19, 2009 02:09 PM
crxzcracer
Apr 9, 2004 08:05 AM
SloCivicHMM
Aug 6, 2003 07:41 AM
