Are D-series and B-series FPRs the Same?
Old Sep 26, 2005 | 06:19 PM
Nisif's Avatar
Default Are D-series and B-series FPRs the Same?
Like the title says, didn't find anything on a search
Old Sep 26, 2005 | 06:20 PM
Nisif's Avatar
Default Re: Are D-series and B-series FPRs the Same? (Nisif)
Specifically Oem FPRs
Old Sep 27, 2005 | 05:50 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
if you are talking about internal, yes. externally, no the bolt pattern is off, but i mean your vac and return lines hook up the same and all it just mounts different. i want to say the b series mount holes and pressure port inlet are all inline and d series is a weird slight triangle configuration. i have rigged a d series regulator to work on a b series rail with no adapters.
demonic_sol13
May 3, 2008 07:32 PM
.David
Sep 19, 2004 09:33 PM
Den-Man07
52
Aug 1, 2004 10:55 AM
bluescrews
Nov 12, 2003 09:11 AM
mannyman
Sep 14, 2002 08:45 AM
