Skunk 2 Lower Tie Bar Install?
Old Sep 26, 2005 | 06:10 PM
Ls InTeGrA RaCeR's Avatar
Default Skunk 2 Lower Tie Bar Install?
Hey guys I just bought a used Skunk 2 Lower Tie Bar for my Ls Integra but with no instructions its hard for me to figure out where to install this thing. If anyone has some pics or something else that could help me out I'd appreciate it a lot. I did try to search but never really came up with anything (maybe the wrong words?).
Old Sep 26, 2005 | 06:46 PM
DANG YO's Avatar
Default Re: Skunk 2 Lower Tie Bar Install? (Ls InTeGrA RaCeR)
question, why did u buy something if u dont know where it goes?
heres mine
Old Sep 26, 2005 | 06:53 PM
Default Re: Skunk 2 Lower Tie Bar Install? (dc2kid)
could you get a clearer pic...? It helps a little but a clearer pic will help me more.
Old Sep 26, 2005 | 07:32 PM
Corporation's Avatar
Economic Upturn, WUT
From: Alittle Placed Called None of Your Damn Business.
All the install takes is some tools, elbow grease, and common sense.
Old Sep 26, 2005 | 07:36 PM
Monkey Z.'s Avatar
unbolt the LCA bolts that are farthest from the wheel, put tie bar on bolt, bolt LCA bolts back in place.. LCA bolts can be a b*tch just to let u kno
Old Sep 26, 2005 | 07:52 PM
00IntegrAllmotoR's Avatar
HT Black OPs
Default Re: (Monkey-DA)
also the lower tie bar does not work to its full potential unless you weld the brackets to the sub-frame so they don't move with the suspension.
Old Sep 26, 2005 | 08:22 PM
SilverDC4's Avatar
Default Re: (00IntegrAllmotoR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00IntegrAllmotoR &raquo;</TD></TR><TR><TD CLASS="quote">also the lower tie bar does not work to its full potential unless you weld the brackets to the sub-frame so they don't move with the suspension.</TD></TR></TABLE>
We don't have itrs, so we're stuck with what we have
Old Sep 27, 2005 | 03:54 AM
Default Re: (SilverDC4)
ok guys that helps me a little more.
Old Sep 28, 2005 | 03:17 PM
Default Re: (Ls InTeGrA RaCeR)
Does anyone have a clearer pic...??
Old Sep 28, 2005 | 03:23 PM
Racermech's Avatar
you dont need a clear pic, look under the car, you will see the 2 inner LCA bolts, jack the car up remove the bolts, slide the bar over the new bolts, thread the new bolts back in place. you are done. Really it is a 20min install (depending on how hard your LCA bolts are to get back in)
Old Sep 28, 2005 | 04:08 PM
cleanDA9's Avatar
go to g2ic. i know it's a generation 2 integra site but they have tips on there. they show you how to do it. it's still basically the same.
Old Sep 28, 2005 | 04:42 PM
Default Re: (cleanDA9)
well I think I'm dealing with a bad part. I bought a bar that would fit a 96-00 civic (part # is the same for the integra, del sol, etc...) so I figured it'd work but if it goes to the LCA's then its short about 4-6 inches.
Old Sep 28, 2005 | 04:47 PM
Chewie's Avatar
it should be adjustable
Old Sep 28, 2005 | 05:38 PM
Default Re: (Chewie)
I'm actually guessing its from a 96+ Civic (which would make it the wrong part for my car). How different are the two parts? Anyone know?
KGB_JDM
Feb 11, 2010 06:54 AM
obuhmyuh
Nov 21, 2007 08:46 PM
98GSRDC2
Mar 5, 2007 08:42 PM
ramz7887
Aug 8, 2003 04:07 PM
K-Bom05
Nov 23, 2002 01:29 AM
