Skunk stage 1 cams w/stock R valve train?
Old Mar 1, 2002 | 11:53 PM
Rhetoric's Avatar
Default Skunk stage 1 cams w/stock R valve train?
Would the stock R valve train be able to handle skunk stage 1 cams with a 9200 p28 rev limit?
Old Mar 2, 2002 | 12:40 AM
StinkyTofu's Avatar
Default Re: Skunk stage 1 cams w/stock R valve train? (G S R)
I've talked to a few members on the board, and i've gotten mixed reviews. Some say you'd be crazy as hell to rev to 9000 rpm daily with those cams and on stock R valvetrain. Some say that if you get ti-retainers you'll be fine and can shift at 9000 rpm however many times you want. I too would like to know for sure.
Old Mar 2, 2002 | 06:46 AM
TypeRdude's Avatar
Default Re: Skunk stage 1 cams w/stock R valve train? (B-18C1)
Anything over stock redline is going to require new valve springs, especially 9krpm. If you plan on revving that high you should probably get the stage 2 skunks since they will have more power accross the entire upper rpm range.
Old Mar 3, 2002 | 12:01 PM
Rhetoric's Avatar
Default Re: Skunk stage 1 cams w/stock R valve train? (TypeRdude)
Would portflow inner springs be sufficient enough with ti retainers?
Old Mar 3, 2002 | 12:17 PM
CKDC2's Avatar
2 years now with R cams, springs and Ti retainers, 9200 rpm P72, no problems. I spoke with JG about this two years ago and he even said they have guys using GSR springs and have had no problems with 9000rpm limiters. I usually shift around 8700- 8900 but it's nice having the extra 300rpm's on some autoX course's where I really didn't want to shift into third.
dc4teg95
Jun 9, 2008 04:18 PM
eg-ed
Aug 21, 2006 12:12 AM
eg-ed
Aug 20, 2006 03:24 PM
j_quan
May 4, 2005 09:35 AM
grenthang
Mar 13, 2005 11:57 AM
