Vafc 2 help with speedo
Old Sep 26, 2005 | 03:50 PM
dohcMONSTER's Avatar
Default Vafc 2 help with speedo
alright i installed a VAFC2 today and now my speedo/vtec doesnt work.
Now before you reply. it worked previously for about 2 hours of driving, then i went to start it and now it doesnt work. Everything runs exactly the same, (idles/drives) there is just no speedo or vtec. please help this is really annoying. TIA
Old Sep 26, 2005 | 03:54 PM
SuperSteve737's Avatar
Check for any loose connections from the ECU, I had that problem. You are down there pulling and tugging on wires, sometimes **** happens.
Old Sep 26, 2005 | 04:19 PM
Default Re: (SuperSteve737)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperSteve737 &raquo;</TD></TR><TR><TD CLASS="quote">Check for any loose connections from the ECU, I had that problem. You are down there pulling and tugging on wires, sometimes **** happens.</TD></TR></TABLE>
tried that and everything is fine, it worked perfect for about half the day and then all the sudden when i went to drive home it didnt work. but those are the only 2 things not working
Old Sep 26, 2005 | 04:26 PM
hmmmm...if all you did was play with the wires down by the ECU, and they are still fine, I can't help you. But bump.
Old Sep 26, 2005 | 04:49 PM
thanks, anyone else?
juanchoenuncrx
Oct 30, 2007 08:39 PM
dohcMONSTER
Sep 26, 2005 04:49 PM
h22a92accordex
Aug 5, 2005 12:18 PM
SlippylesKB
20
Oct 18, 2003 04:32 PM
cr00klyn718
Jun 13, 2003 05:33 AM
