spark plugs
Old Sep 26, 2005 | 02:52 PM
sa90eg's Avatar
Default spark plugs
just wanted to knoe wat plugs do you guys use on your build motors....
(simple 86x89 max comp 2.0L,pnp head, cams header,ect....230ish+HP)
Old Oct 24, 2005 | 08:15 AM
cpforyou's Avatar
Default Re: spark plugs (sa90eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sa90eg &raquo;</TD></TR><TR><TD CLASS="quote">just wanted to knoe wat plugs do you guys use on your build motors....
(simple 86x89 max comp 2.0L,pnp head, cams header,ect....230ish+HP)</TD></TR></TABLE>
NGK BKR7E-11 V-Power Spark Plugs should be a good spark plug to run with that setup.
Some people might want to consider the NGK Temp 8 Race Plugs, depending on the timing you want to run, the octane you plan on running, etc.
Old Oct 24, 2005 | 10:00 AM
Rocket's Avatar
Default Re: spark plugs (cpforyou)
How tall is your dome on the piston?
Old Oct 24, 2005 | 12:14 PM
gsrious's Avatar
hey josh... you should try out the ngk r5671a8
i think those plugs will do your car some good with its non projected electrode and it's heat range of 8. your car does generate alot of heat.
Old Oct 24, 2005 | 12:21 PM
rjay8604's Avatar
Default Re: (gsrious)
It seems 7 heat range NGK's are the way to go. You pretty much want to go with the "hottest" plug you can run safely. And in most cases with built street motors 7's seem to be the best. I run BKR7E-11 NGK's, just the V-power copper electrode.
Modified by rjay8604 at 5:50 PM 10/24/2005
Old Oct 24, 2005 | 12:30 PM
gsrious's Avatar
Default Re: (rjay8604)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjay8604 &raquo;</TD></TR><TR><TD CLASS="quote">It seems 7 heat range NGK's are the way to go. You pretty much wan't to go with the "hottest" plug you can run safely. And in most cases with built street motors 7's seem to be the best. I run BKR7E-11 NGK's, just the V-power copper electrode. </TD></TR></TABLE>his car is not a street car. it's an all out drag car.
Old Oct 24, 2005 | 06:08 PM
LSVTEC 91 Civic's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjay8604 &raquo;</TD></TR><TR><TD CLASS="quote">It seems 7 heat range NGK's are the way to go. You pretty much want to go with the "hottest" plug you can run safely. And in most cases with built street motors 7's seem to be the best. I run BKR7E-11 NGK's, just the V-power copper electrode.
Modified by rjay8604 at 5:50 PM 10/24/2005</TD></TR></TABLE>
BKR7E-11
OneCrzySetup
Nov 17, 2006 11:53 AM
2001accord
Jul 7, 2005 03:24 PM
hybrid_vtec
15
Jul 30, 2004 01:37 PM
blackccoupe
Mar 31, 2004 02:50 PM
