obd1 motor in obd 1 car with obd2 cat? will it pass ref?
Old Sep 26, 2005 | 02:31 PM
Kyles ej1's Avatar
Default obd1 motor in obd 1 car with obd2 cat? will it pass ref?
i have an obd1 ls in my 93 civic. everything went in fine, its stock and im not throwing any codes. the only thing i didnt have is the cat so im running open header while i find one. i found a couple of obd2 cats but no obd1. i know both will bolt up but for the obd2 i would have to put a bolt or something in the cat, will that fly with the ref and smog stations? do they just check that i have a cat or do they actually inspect it?
Old Sep 26, 2005 | 03:24 PM
Cypher0117's Avatar
Default Re: obd1 motor in obd 1 car with obd2 cat? will it pass ref? (Kyles ej1)
hmmm.....it would most likely pass smog. the obd1 motor isn't even checking for the second o2 sensor. you'd probalby have to plug the hold w/ something but idk....
would probably work
but
don't take my word for it
Old Sep 26, 2005 | 03:26 PM
Kyles ej1's Avatar
Default Re: obd1 motor in obd 1 car with obd2 cat? will it pass ref? (Cypher0117)
i know plugging it will work cuz my friend did for his pos ford. and since the only is in the exhaust manifold it wont throw a code or nothing but i was mainly concerend about it passing the visual
Luserkid's Avatar
I have only heard of 1 ref actually going under the car and reading the numbers on the cat. but that guy was a major dick. I really doubt theyll do that to you. You should be fine.
Old Sep 26, 2005 | 03:47 PM
Kyles ej1's Avatar
Default Re: obd1 motor in obd 1 car with obd2 cat? will it pass ref? (Luserkid)
im going to the ref at my school and i know the guy there is pretty cool. i was even going to grind it down and paint it like flat black or brown or whatever would match the cat good. where is the bung on obd2 cats? is it visibal if you lookunder there?
Old Sep 26, 2005 | 04:19 PM
Kyles ej1's Avatar
does any ref even check the cat or do they just look at the engine bay and throw it on a dyno?
Old Sep 26, 2005 | 05:29 PM
Luserkid's Avatar
When i went they checked the motor then through it on the dyno. The O2 bung should be right on the top i believe in the front. You could easily weld it up or put a bolt in it if you already have one.
Old Sep 26, 2005 | 05:33 PM
dantastic's Avatar
i used an aftermarket cat (oem replacement) to get my BAR sticker. they just looked to see if there was a cat at all. just make sure the obd2 cat is the right length and flange orientation. then plug up the secondary 02 bung on the obd2 cat.
theslugbug
Sep 30, 2009 11:49 AM
eastbay92cx
May 11, 2006 12:43 AM
eh2+b18c1=usdm sleeper
Nov 22, 2004 07:48 AM
96dc2
Oct 24, 2003 07:18 PM
