need help on some codes...
Old Sep 26, 2005 | 02:06 PM
civics8900's Avatar
Default need help on some codes...
i have a 2000 civic with a b16 manual swap..my car is throwing a p1399 code, which is a controlled ignition system or misfire.. and a p0141 code which is a 02 sensor heater circuit malfunction..(bank 1 sensor 2). i have no idea what to do. i need help. asap... what is wrong with my car and what should i do..
Old Sep 26, 2005 | 03:19 PM
drdisco69's Avatar
Default Re: need help on some codes... (civics8900)
You need a new secondary O2 sensor and you need to diagnose a misfire. Aftermarket ignition components are a no-no, and worn OEM components should be replaced.
Old Sep 26, 2005 | 05:31 PM
civics8900's Avatar
Default Re: need help on some codes... (drdisco69)
hey is the secondary o2 sensor on the cat. or the header? thanks for your help..
Old Sep 26, 2005 | 06:26 PM
IMALLSLO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civics8900 &raquo;</TD></TR><TR><TD CLASS="quote">hey is the secondary o2 sensor on the cat. or the header? thanks for your help.. </TD></TR></TABLE>\
On the catalytic.
stehigs321
Jan 1, 2005 07:14 AM
Ge.ES.AHH
Oct 10, 2004 11:21 PM
boostmywankle
Apr 28, 2004 03:50 AM
chads
Jan 20, 2004 05:07 PM
quik2kSi
Sep 22, 2002 07:08 PM
