Hasport Mounts; H22 93 civic Ex. Will Power steering work?
I am working on getting the H22 swap finished up in my 93 civic ex.
the power steering pump is hitting the rad support just behind the headlight, needs another about 1/2-3/4 inch clearance, and it looks awfully close on the belt too.
just wondering if anyone has gotten it to fit, or work in this combination.
and tips on getting it to fit nicely would be much appreciated.
heres a "how to" if you are using the stock 92-95 jdm power steering pump. https://honda-tech.com/zerothread?id=922811
I heard if you use a 97+ pump and bracket it should clear with out a problem.
Yes the belt is very close but you should still be ok.... depends on the mounts. I have hcp and its clears but close.
PS: for those who read this, with an integra using the stock 92-95 jdm pump, all you need to modifie is the power steering line. the headlight clearence is fine.
Drkaccrd
Jan 30, 2003 02:30 PM
